John90290 |
Member ![]() ![]() Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None ![]() |
Adjusting the valves on my 1975 1.8 that I just put new pistons in. I’m going through the process as outlined on a few manuals but for some reason it doesn’t feel right? I’ve never done this before so the manuals I have don’t really have good pictures and the videos and such just say go to tdc and adjust. I get to the tdc mark but feel I need to turn it a bit more to get the valves on the number one to fully close. Also when I move on the the other cyclyndsrs after moving the crank 180 degrees, the ones I previously adjusted seem loose. Not sure if thes makes sense. I don’t want to get it back in the car and have it not run.
I’ve seen valve adjustment discussions on this forum before but couldn’t find them doing the search. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
hE'S jOKING. dON'T UNLESS YOU WANT TO TAKE THE MOTOR OUT TO GET THE BROKEN CHOPSTTICK OUT. (IMG:style_emoticons/default/biggrin.gif) Krusty is the right way. Read it about 6x and it'll make sense and easy to do. |
Mark Henry |
hE'S jOKING. dON'T UNLESS YOU WANT TO TAKE THE MOTOR OUT TO GET THE BROKEN CHOPSTTICK OUT. (IMG:style_emoticons/default/biggrin.gif) Krusty is the right way. Read it about 6x and it'll make sense and easy to do. Dats teh tooth! (IMG:style_emoticons/default/tooth.gif) |
Lo-Fi Version | Time is now: 24th June 2024 - 07:03 AM |
