Fuel Pump Relocation, early to late, Wiring |
Aerostatwv |
Dec 27 2018, 10:02 AM
Member Group: Members Posts: 118 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
Greetings! For the folks that have moved their fuel pumps to the front of their cars, what is the best method for relocating the pump electrical wiring? I am having trouble finding a thread that addresses this. Thanks!
bbrock |
Dec 27 2018, 11:33 AM
As Jeff Bowlsby pointed out to me, Porsche increased the fuel pump wire to 12 gauge when they relocated the pump. I replaced the original pump wire by running a new 12g red/blk wire from the connector on the relay board all the way to the new pump location. I also ran a new 12g brown ground wire from the left headlight ground post to the new pump location. There is a closer ground post below the air box up front but I wanted to integrate the new wire in the main harness and the left headlight bucket made more sense. It doesn't HAVE to be done that way, but that's what I did to keep the factory wiring schematic accurate and using the appropriately sized wire to accommodate the longer wire run. I had the harness out of the car though so kind of cheating.
ClayPerrine |
Dec 27 2018, 12:44 PM
Life's been good to me so far..... Group: Admin Posts: 15,580 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
As Jeff Bowlsby pointed out to me, Porsche increased the fuel pump wire to 12 gauge when they relocated the pump. I replaced the original pump wire by running a new 12g red/blk wire from the connector on the relay board all the way to the new pump location. I also ran a new 12g brown ground wire from the left headlight ground post to the new pump location. There is a closer ground post below the air box up front but I wanted to integrate the new wire in the main harness and the left headlight bucket made more sense. It doesn't HAVE to be done that way, but that's what I did to keep the factory wiring schematic accurate and using the appropriately sized wire to accommodate the longer wire run. I had the harness out of the car though so kind of cheating. (IMG:style_emoticons/default/agree.gif) I did essentially the same thing on Betty's car. I used the fuel pump wire from a 75 harness, and used the ground by the fuse box. And yes, the harness was out of the car. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:22 PM |
