Recirculation circuit for -6 with carbs.. |
mb911 |
Jan 2 2019, 01:36 PM
914 Guru Group: Members Posts: 6,977 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I know @MarkHenry has talked about this but I want to also do this and have a few questions..
I need to buy my stainless lines for my car and my question is that I have a PMO regulator that has a return to the tank and am using Webers on my -6.. Should I be running all 4 lines from Tangerine or is there another better option?? I want this system safe.. |
db9146 |
Jan 2 2019, 02:30 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Ben,
Just curious....if carbs typically require 3 to 4 or so lbs. of pressure, are you talking about running higher pressure and letting the reg. return anything higher than required to the tank? I know you do this on a fuel inj. system, but what's the advantage to doing this with carbs? |
Lo-Fi Version | Time is now: 28th June 2024 - 01:36 PM |
