mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,953 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
I know @MarkHenry has talked about this but I want to also do this and have a few questions..
I need to buy my stainless lines for my car and my question is that I have a PMO regulator that has a return to the tank and am using Webers on my -6.. Should I be running all 4 lines from Tangerine or is there another better option?? I want this system safe.. |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Couple questions:
1) I think Mark mentioned this on other threads, but with a bypass regulator and return line, you should be able to run the stock FI pump on a /4, correct? What are the pros and cons of running a higher pressure pump with a bypass? One advantage for me is one less thing to buy but wondering about performance, reliability, and longevity. 2) What is the advantage of D over C? C looks to be the stock setup with allowance for a relocated pump. Just curious. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:42 AM |
