Recirculation circuit for -6 with carbs.. |
mb911 |
Jan 2 2019, 01:36 PM
914 Guru Group: Members Posts: 7,159 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I know @MarkHenry has talked about this but I want to also do this and have a few questions..
I need to buy my stainless lines for my car and my question is that I have a PMO regulator that has a return to the tank and am using Webers on my -6.. Should I be running all 4 lines from Tangerine or is there another better option?? I want this system safe.. |
IronHillRestorations |
Jan 4 2019, 02:31 PM
I. I. R. C. Group: Members Posts: 6,759 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The PMO fuel rails are made so you can screw small pre-filters in them.
Before you go too far, just remember there's scores of cars out there with low pressure rotary fuel pump (with a 3.5 psi output) feeding two carbs without a fuel pressure regulator, or return line, and running just fine. I wouldn't use an Airtex even if I owned a parts store, they a junk |
Lo-Fi Version | Time is now: 25th September 2024 - 10:40 PM |
