oil pressure switch |
porsche-tom |
Jan 5 2019, 06:55 AM
Member Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None |
I have a pretty decent oil leak coming from or around the oil cooler. I have a new oil cooler with new seals but I think i should replace the oil pressure switch while I am at it. where is the switch located? any tips for replacing the oil cooler?-thanks
Mark Henry |
Jan 5 2019, 08:49 AM
The switch is sort of under the distributor, right above the oil cooler, look for the wire.
I would definitely install a new switch before I messed with the cooler, a lot of the time it is just the switch leaking. |
dr914@autoatlanta.com |
Jan 5 2019, 09:47 AM
914 Guru Group: Members Posts: 7,911 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes like Mark said this one leaks first, to the left rear of the distributor down in the sheet metal hole with a rubber boot on top and a green with red wire connected. If leaking will be loose you can wiggle the top of it, and or have oil around it. Will have to pull off the boot first to inspect
The switch is sort of under the distributor, right above the oil cooler, look for the wire. I would definitely install a new switch before I messed with the cooler, a lot of the time it is just the switch leaking. |
jdamiano |
Jan 5 2019, 03:27 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
yes like Mark said this one leaks first, to the left rear of the distributor down in the sheet metal hole with a rubber boot on top and a green with red wire connected. If leaking will be loose you can wiggle the top of it, and or have oil around it. Will have to pull off the boot first to inspect The switch is sort of under the distributor, right above the oil cooler, look for the wire. I would definitely install a new switch before I messed with the cooler, a lot of the time it is just the switch leaking. Not my post originally but I’m dealing with the same thing. I spoke with George yesterday and asked him to send me some new oil cooler seals. I just took a closer look at the switch and it is wet. Do I have to replace the entire switch or is it a seal? If you see this before you send my cooler seals George send what I need for the switch leak as well. |
Lo-Fi Version | Time is now: 24th June 2024 - 06:33 AM |
