Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Hi guys, hope everybody’s having a good week so far.
The parking brake on the 73 1.7 car has always been extremely stiff, and when I pulled the cover in the cockpit today here’s what I found. From doing some research I believe these are supposed to be even as opposed to skewed to one side, is that correct? ![]() Thanks! |
Tbrown4x4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 705 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None ![]() ![]() |
The handle has a bushing. Probably not that.
The cables can rust and cause binding. (They could be adjusted too tight as well.) And don't get me started on the rear calipers. I would pull the cables off the rear caliper levers and see if it changes. A lot of people don't use the parking brake (any car, any year), and that lack of use can let things corrode. You could be in for a rear caliper rebuild. Probably good preventative maintenance anyway. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:59 PM |
