BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Ok, may be a stupid question, but this is my first Type 4 assembly, so bear with me:
Is it critical that the connecting rods be oriented a specific way on the crank? I've got the numbers matched (rod to cap) properly, but how critical is it for the numbers to point up when the crank is flat as Raby mentions in his video? I got turned around and realized I oriented at least one differently. In the Wilson book he seems to mention that Type 4 are symmetrical and don't really matter (whereas Type 1 etc. need to have the bump on the rod facing up). If it is critical, I suppose I need new rod bolts now that I've torqued them to spec? These are H-Beam. TIA. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Type 1 it matters as there's an offset on the big end, there's a bump on the stock rod that has to face up. If you're using a T4 stroker crank with T1 rods it matters.
I was always told unmarked symmetrical rod the bearing go tangs down, but honestly it doesn't matter, I just do it out of habit and so it doesn't freak out the next engine builder. First time I installed M96/97 Carrillo (996) rods I emailed Carrillo and asked if orientation mattered, the reply was a simple "Symmetrical rod, no it doesn't". ARP rod bolts/nuts can be torqued/reused several times as long as it maintains proper stretch spec. If not ARP I'd email the manufacturer (CB, SCAT) but likely their bolts can be reused as well. |
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Type 1 it matters as there's an offset on the big end, there's a bump on the stock rod that has to face up. If you're using a T4 stroker crank with T1 rods it matters. I was always told unmarked symmetrical rod the bearing go tangs down, but honestly it doesn't matter, I just do it out of habit and so it doesn't freak out the next engine builder. First time I installed M96/97 Carrillo (996) rods I emailed Carrillo and asked if orientation mattered, the reply was a simple "Symmetrical rod, no it doesn't". ARP rod bolts/nuts can be torqued/reused several times as long as it maintains proper stretch spec. If not ARP I'd email the manufacturer (CB, SCAT) but likely their bolts can be reused as well. Which way is UP relative to the rod? Got a set of the Type 4 Stores rods for strokes and T1 journals. Can’t really distinguish an up. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:40 AM |
