pullin it back out...., oil leak, vacuum leak, temp calibration. |
crash914 |
Nov 24 2004, 06:56 AM
its a mystery to me Group: Members Posts: 1,827 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Got the big 4 running...I have a few things to fix....
Oil leak from the rear...I hope it is just a galley plug that I need to tighten, small oil leak from the front, guess I need to install the oil pump gasket.... These are small easy fix items...I did safety wire the CV bolts so I need to take all that back apart....bummer..... Found a cool problem with the throttle bodies...on the 1/2 side, I can cover the stacks and the motor still runs the same...if I do it on the 3/4 side, the idle falls off...so I got a big vacuum leak somewhere... These are webber throttle bodies....I think the problems is at the manifold head interface...I have to pull the motor anyway..... The second problem is the easytherm calibration of the CHT....Dave, got any ideas? No matter how I change the settings, I read -40 deg. and am stuck in warm up mode... Other than that, this rocks! The megasquirt fires right up and I can adjust AFR at all rpm's..with this cam my vacuum signal is around 57 to 60 Kpa. when I fix the vacuum leak, I should have a better signal... Oh yes...this is a 103 mm Nickie by 80 mm 2.666L motor, with webber twin throttle bodies and a 163/86b cam and lots of head work. Anyone want to help pull the motor this weekend??????? Will supply beer and soda..... (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 28th September 2024 - 10:16 AM |
