> Replacing trunk hinge, Success, and hinge bolt mod.
Olympic 914
post Dec 4 2018, 02:38 PM
Going to have to repair/replace the trunk hinge on the car this winter. It was repaired before.... but it failed in a different spot. I wonder if the trunk lid gasket was too tight and caused this failure?
I am planning on taking the engine out to make it easier to get in there and position it correctly and do a good job welding.
How many of you have done this repair leaving the engine in?
I am not an experienced welder and trying to weld it while bent over the fender and trying to even get the mig in there seems too hard.
I have already had the engine out twice since last Oct. so I am getting quite good at it.
Olympic 914
post Jan 26 2019, 03:00 PM
OK, decided to pull the engine to do this job.
Taped cardboard all around to protect the paint from grinding and welding spatter.
Cut the old ones out. the best way to locate the position is to mount the hinges to the trunk lid, put it in place lining up the trunk and then put a couple spot welds on it to hold things. take it back apart and then weld it up right.
After getting in there I didn't like the looks of the other hinge, So I cut them both out. and ordered new mounts form RD
Got the old ones cut out.
New mounts welded in. much easier without the engine in. you can just sit on a little stool and weld away...
Didn't want this happening again, and someone else had mentioned doing a grease fitting mod to the bolts. so over the lathe for a bit to cut a grease groove, then drilled and tapped for a fitting.
I also polished off all the paint on the mating surfaces with a wire wheel in the Dremel
Easy to get a grease gun in there and put a couple squirts in to keep things moving smoothly.
Kind of looks like it should be this way.
Olympic 914   Replacing trunk hinge   Dec 4 2018, 02:38 PM
mepstein   If you don’t need it to be original, Jwest makes...   Dec 4 2018, 02:40 PM
jcd914   If you don’t need it to be original, Jwest make...   Dec 4 2018, 06:10 PM
dr914@autoatlanta.com   engine in easy if you can spot weld, and now with ...   Dec 4 2018, 05:14 PM
dr914@autoatlanta.com   by the way in the back of the tech tips 700 is the...   Dec 4 2018, 05:15 PM
Olympic 914   by the way in the back of the tech tips 700 is th...   Dec 4 2018, 05:59 PM
dr914@autoatlanta.com   the bottom of page 132 by the way in the back o...   Dec 5 2018, 03:22 PM
Olympic 914   Damn.... My copy only goes to pg 125. :huh: :hi...   Dec 5 2018, 06:05 PM
914werke   The failure mode isn't tension, but rust. Or m...   Dec 4 2018, 06:34 PM
914_teener   The failure mode isn't tension, but rust. Or ...   Dec 4 2018, 06:54 PM
amfab   +2 for the JWest system. Hardest part was getting ...   Dec 5 2018, 02:58 PM
rgalla9146   See current thread...'Replacing bracket for h...   Dec 5 2018, 08:10 PM
Tdskip   I haven't done it (yet) but I believe the JWes...   Dec 6 2018, 08:16 AM
Olympic 914   OK, decided to pull the engine to do this job. ...   Jan 26 2019, 03:00 PM
second wind   OK, decided to pull the engine to do this job. ...   Jan 27 2019, 01:44 PM
914forme   :agree: They look great, that trick was published ...   Jan 26 2019, 06:12 PM
Olympic 914   :agree: They look great, that trick was published...   Jan 26 2019, 08:45 PM
914forme   :agree: They look great, that trick was publishe...   Jan 26 2019, 11:04 PM
IronHillRestorations   Bingo! That's what I call the "Upfix...   Jan 26 2019, 09:04 PM
windforfun   I replaced my plastic rollers with metal ones. I ...   Jan 27 2019, 11:23 AM
second wind   So......any chance of making a bunch of those nift...   Jan 27 2019, 01:47 PM
- Lo-Fi Version Time is now: 12th April 2025 - 02:35 AM
