914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,921 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Saw these on Ebay. I don't remember any information on these. Maybe the guys at 914 Rubber will chime in.
Attached image(s) ![]() |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Good speaker if you can drive them is Infinity, the reference comes in a 6.5" with a shallow depth mount. Here
Or if you have the depth the Kappa series would be a great choice. Here. These Kappa's you can tip the tweeters to get them closer to a direct line of your ears. Both have a sensitivity of 93 dB or great, but they drop into the 2 to 3 Ohm range, some head units will not like that. But changing Ohm range is a pretty easy step. If you where going for the ideal setup, the drivers side would be angled closer to your left, almost firing right up your leg, and the right would be tilted upwards towards your right year. Being ABS that could still be done, but why (IMG:style_emoticons/default/confused24.gif) |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Good speaker if you can drive them is Infinity, the reference comes in a 6.5" with a shallow depth mount. Here Or if you have the depth the Kappa series would be a great choice. Here. These Kappa's you can tip the tweeters to get them closer to a direct line of your ears. Both have a sensitivity of 93 dB or great, but they drop into the 2 to 3 Ohm range, some head units will not like that. But changing Ohm range is a pretty easy step. If you where going for the ideal setup, the drivers side would be angled closer to your left, almost firing right up your leg, and the right would be tilted upwards towards your right year. Being ABS that could still be done, but why (IMG:style_emoticons/default/confused24.gif) To change the part we would have to change the mold, sounds like your talking a significant change. Our point here is to save the door panels and give something that is somewhat stock looking. How many degrees would it have to be changed? It would be possible to shim the back out a few, but at a certain point you interfere with the drivers leg. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:15 AM |
