> Electric Windshield Washer Conversion 914, Complete kit
rothaus
post Jul 15 2018, 01:20 PM
On the Porsche 914 the original windshield washer is operated by compressed air supplied from the Spare tire.
Here is the switch that replaces the original valve in the steering column. With this switch installed, an electrical washer pump can be operated with the wiper switch.
(IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1531682421.1.jpg)
I got some requests if it would be possible to have a complete kit available. So I put together a complete kit, and also have now options. It's not yet on the website, however here is the information with the options and prices.
Option 1: Switch only - $15.00 PLUS $5 s/h
Option 2: Relay kit only - $35.00 plus $6 s/h
Option 3: Switch and relay kit - $50.00 plus $6 s/h
Option 4: Option 3 plus pump - $72.00 plus $8 s/h
The switch is pre-wired and includes the mounting plate and some washer for adjustment if needed.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-12404-1623100568.1.jpg)
The relay kit includes all wires, a fuse, and connectors, shrink tubing, bolt to mount the relay, as well the disc for the filler cap.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-12404-1623100568.2.jpg)
Here is the wire diagram which will also be included in the step by step instructions.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg)
The switch can be ordered at http://carmagic.us/washer.html
Cheers
Engelbert
davep
post Feb 8 2019, 10:45 PM
914 Historian
The wiring is very simple. From a fused 12 volt source (fuse panel) run a hot wire to the pump positive side. From the pump negative side run a wire to the switch. From the other side of the switch run a ground wire to the multiple ground stud near the fuse box. I am not sure what the switch rating is, so a relay could be added to keep the switch current in line with it's rating. I came up with a mounted switch years ago to do this very task.
http://www.914world.com/bbs2/index.php?sho...7916&st=29#
rothaus   Electric Windshield Washer Conversion 914   Jul 15 2018, 01:20 PM
orthobiz   I did this conversion in the 80's on an old ca...   Jul 19 2018, 04:24 AM
Mikey914   I did this conversion in the 80's on an old c...   Feb 29 2020, 08:27 PM
bretth   Awesome! Beats having windshield fluid drippin...   Jul 19 2018, 06:20 AM
amfab   well thats just a fantastically simple solution. W...   Sep 13 2018, 08:38 PM
cary   That's cool ............. Well done. I think I...   Sep 15 2018, 09:21 AM
BillC   I installed one of these in my 914 a couple of wee...   Oct 23 2018, 04:25 PM
buck toenges   Can somebody help me with the electrical hook up? ...   Feb 7 2019, 03:19 PM
rothaus   Here is a video from A electric washer pump conver...   Feb 7 2019, 07:11 PM
davep   The wiring is very simple. From a fused 12 volt so...   Feb 8 2019, 10:45 PM
rothaus   Ok, here is my recommended wire diagram for the wa...   Feb 10 2019, 05:04 PM
cary   Bump   Jan 25 2020, 12:18 AM
russmoffat   I did this exact setup here. Wondering if anyone e...   Feb 28 2020, 08:34 PM
FUEL14   If I want to use the column stalk for the washer, ...   Sep 9 2020, 06:06 PM
FlacaProductions   @FUEL14 - yes. I did just that. Just use the ne...   Sep 11 2020, 09:12 AM
FUEL14   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 11 2020, 06:07 PM
ThinAir   Where has this been all my life? Ordered!...   Oct 21 2020, 02:31 PM
DRPHIL914   Ok, here is my recommended wire diagram for the w...   Apr 25 2021, 04:53 PM
rothaus   [quote name='rothaus' post='2688041' date='Feb 10...   Apr 26 2021, 05:26 AM
DRPHIL914   [quote name='rothaus' post='2688041' date='Feb 1...   Apr 26 2021, 08:18 AM
Warren914   The only issue I see using that relay is the poten...   Jun 8 2021, 09:22 AM
Zaffer   Will definitely order soon as I expect to have the...   Apr 25 2021, 08:10 PM
cary   We've installed a couple without any issues in...   Apr 25 2021, 08:20 PM
rothaus   I added some options and now a complete kit is ava...   Jun 7 2021, 03:26 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th November 2024 - 01:53 PM
