MiniStevieG |
Member ![]() ![]() Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region ![]() |
Experiencing some issues when shifting gears. I’m finding that even with the clutch pedal pressed the entire way to the floor I’m grinding a bit when shifting. I did a bit of research and decided to adjust the tensioner on the back cable assembly.
First I tried tightening the nut thinking this would help the clutch to engage sooner but in fact the issue appeared worse after I tightened it. I then adjusted the nut back to where I started and tried loosening it but that didn’t help either. Anyone care to take a stab at what the issue might be? New cable assembly maybe? Pressure plate? Thanks everyone!! |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Two inspection plates on the center tunnel. Front is under the carpet by the pedal assembly. 2nd under the center cushion or tray. Take rear cover off and watch tube as someone pushes in the clutch. You will probably see tube moving when depressed.
MiniStevieG |
Two inspection plates on the center tunnel. Front is under the carpet by the pedal assembly. 2nd under the center cushion or tray. Take rear cover off and watch tube as someone pushes in the clutch. You will probably see tube moving when depressed. I was able to get a look after removing the seats and center console and peeling back the carpet. Front inspection area by the pedal assembly seems good. But yes the tube is moving further back but only slightly under the area near the shift yoke when the clutch is pushed. Appears there was some fiberglass work under the car due to rust I assume so I’m not able to get a very good look at how/if the tube is mounted proper without cutting in that area. So before I get to cutting I’m curious if this could even remotely be related to transmission fluid level being low or something else? |
MiniStevieG |
Two inspection plates on the center tunnel. Front is under the carpet by the pedal assembly. 2nd under the center cushion or tray. Take rear cover off and watch tube as someone pushes in the clutch. You will probably see tube moving when depressed. I was able to get a look after removing the seats and center console and peeling back the carpet. Front inspection area by the pedal assembly seems good. But yes the tube is moving further back but only slightly under the area near the shift yoke when the clutch is pushed. Appears there was some fiberglass work under the car due to rust I assume so I’m not able to get a very good look at how/if the tube is mounted proper without cutting in that area. So before I get to cutting I’m curious if this could even remotely be related to transmission fluid level being low or something else? Okay so I cut the center tunnel behind the cross brace and yep the bracket is broke. Shouldn’t be a problem welding this to the floor. Makes me nervous using the cutting tool with all the sparks near that gas line though. It looks awful at the firewall as well but that area certainly looks harder to access. While I’m hopeful this fixes the gear grinding issues I’m not entirely convinced this is the fix because there is still minimal flex on the tube when the clutch is pressed. Gonna weld it up and give it a go. Thanks everyone for your input. ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 02:06 AM |
