Clutch issue or something more?, Need to erase the grind |
MiniStevieG |
Feb 10 2019, 05:17 PM
Member Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region |
Experiencing some issues when shifting gears. I’m finding that even with the clutch pedal pressed the entire way to the floor I’m grinding a bit when shifting. I did a bit of research and decided to adjust the tensioner on the back cable assembly.
First I tried tightening the nut thinking this would help the clutch to engage sooner but in fact the issue appeared worse after I tightened it. I then adjusted the nut back to where I started and tried loosening it but that didn’t help either. Anyone care to take a stab at what the issue might be? New cable assembly maybe? Pressure plate? Thanks everyone!! |
sixnotfour |
Feb 13 2019, 05:25 AM
914 Wizard Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Attached image(s) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:11 AM |
