> A few disconnected parts
isdyl
post Feb 9 2019, 07:10 AM
Region Association: England
Hi - so I'm just preparing for my maiden voyage - the car must have been off the road for at least 10 years judging by the rust in the floor when I got it in June. I've changed the fan belt this morning, but there are a few thingsI saw that I think need tidying. Its got a mid mounted progressive weber (yes I know), and there looks to be a port on each side near where the headers meet the tin - should some pipes be connected to these please? Also in one photo showing the port on the passenger side there is a wire coming out of the tin with a female spade connector - you can see it in the photo. There is also a green with red trace wire coming out of the loom near the distributor which isn't connected to anything.
The car runs, but not well. Not sure how far I will get down the road!
Thanks, Dylan
mgphoto
post Feb 9 2019, 09:23 AM
"If there is a mistake it will find me"
In your first photo it looks like your accelerator cable is wrapped around some wiring, that will cause several problems.
isdyl
post Feb 18 2019, 11:22 AM
Yes, it does look a bit of a mess I admit. The accelerator cable isn't actually touching anything though and is attached to a rather inadequate 32/36 central mounted weber carb. I've got it running ok now, but the throttle doesn't snap shut when you take your foot off the pedal. The spring at the carburettor is ok, but I'm struggling to see if there is any kind of return spring at the foot pedal. Theres some rods that go off somewhere - is there a spring down there too please?
QUOTE(mgphoto @ Feb 9 2019, 09:23 AM) *
mgphoto
post Feb 18 2019, 01:30 PM
QUOTE(isdyl @ Feb 18 2019, 09:22 AM) *
No spring at the pedal for the accelerator, I think it is the brake pedal that has the spring.
isdyl   A few disconnected parts   Feb 9 2019, 07:10 AM
ClayPerrine   Those two open ports are cylinder head vents. You ...   Feb 9 2019, 08:40 AM
isdyl   Thanks very much! Those two open ports are c...   Feb 9 2019, 09:05 AM
isdyl   Those two open ports are cylinder head vents. You...   Feb 13 2020, 12:33 PM
isdyl   Those two open ports are cylinder head vents. Yo...   Feb 14 2020, 07:28 AM
ClayPerrine   [quote name='isdyl' post='2785648' date='Feb 13 2...   Feb 14 2020, 08:13 AM
isdyl   [quote name='isdyl' post='2785648' date='Feb 13 ...   Feb 14 2020, 11:14 AM
mgphoto   In your first photo it looks like your accelerator...   Feb 9 2019, 09:23 AM
isdyl   Yes, it does look a bit of a mess I admit. The acc...   Feb 18 2019, 11:22 AM
mgphoto   Yes, it does look a bit of a mess I admit. The ac...   Feb 18 2019, 01:30 PM
isdyl   Ok thanks - so just the spring at the carb or thro...   Feb 18 2019, 03:51 PM
Rob-O   With the center mounted carb there is usually a sp...   Feb 18 2019, 07:22 PM
isdyl   Thanks - I would definitely consider FI but there ...   Feb 19 2019, 01:50 AM
ClayPerrine   Thanks - I would definitely consider FI but there...   Feb 19 2019, 06:47 AM
isdyl   They don't check emissions on vehicles this ol...   Feb 19 2019, 07:35 AM
PanelBilly   You might check that the throttle wire isn’t wra...   Feb 19 2019, 09:24 AM
isdyl   Thanks, I'll check that. You might check tha...   Feb 19 2019, 11:27 AM
Spoke   If you don't want to do FI, then find a set of...   Feb 19 2019, 09:29 AM
isdyl   Yes a set of dual Weber carbs would be the more ec...   Feb 19 2019, 11:36 AM
mgphoto   '73 model year, the angle of the spark plug sa...   Feb 19 2019, 12:22 PM
isdyl   Thanks for the info. D-jetronic is good news as I ...   Feb 19 2019, 02:29 PM
isdyl   Hi - I'm just eventually starting to fit the d...   Jan 16 2020, 04:16 AM
Spoke   Hi - I'm just eventually starting to fit the ...   Jan 16 2020, 04:49 AM
isdyl   Thanks - that's a great photo to help me get e...   Jan 16 2020, 06:28 AM
isdyl   Hi! That photo has been really helpful and the...   Feb 11 2020, 01:14 PM
rjames   Last pic is of the decel valve. Mounted on the sa...   Feb 11 2020, 06:13 PM
isdyl   Last pic is of the decel valve. Mounted on the s...   Feb 12 2020, 01:16 AM
cwpeden   Check this thread for hoses. I think you have AAR ...   Feb 14 2020, 08:42 AM
isdyl   Check this thread for hoses. I think you have AAR...   Feb 14 2020, 11:27 AM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 11:44 PM
