pneuhyde |
Member ![]() ![]() Group: Members Posts: 94 Joined: 24-February 05 From: San Leandro, Ca. Member No.: 3,654 Region Association: Pacific Northwest ![]() |
I have a 72 with 911 5 lug conversion. I had the engine out and wanted to repack the CV joints so I pulled the axles with the splined stubs out of the wheel housing, thinking it would be best to keep them all together and make it easier to re-install.
Now I need to tow my car to a new work space and found the wheels wobble around without the splined stubs in place. If I install them then they will flop around while being towed. I was going to use a u-haul two wheel tow dolly. Can I mount it with the rear wheels on the dolly and and lock the steering wheel in place to tow straight and will the rear wheels be ok to roll on and off the dolly? Thanks, Steve |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,314 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Now I need to tow my car to a new work space and found the wheels wobble around If you've rolled your car with weight on the rear wheels, you've probably already irepairably wrecked your rear wheel bearings. QUOTE Can I mount it with the rear wheels on the dolly and and lock the steering wheel in place to tow straight...? No, because your steering wheel will not lock in a straight-ahead position. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:46 AM |
