pneuhyde |
Member ![]() ![]() Group: Members Posts: 94 Joined: 24-February 05 From: San Leandro, Ca. Member No.: 3,654 Region Association: Pacific Northwest ![]() |
I have a 72 with 911 5 lug conversion. I had the engine out and wanted to repack the CV joints so I pulled the axles with the splined stubs out of the wheel housing, thinking it would be best to keep them all together and make it easier to re-install.
Now I need to tow my car to a new work space and found the wheels wobble around without the splined stubs in place. If I install them then they will flop around while being towed. I was going to use a u-haul two wheel tow dolly. Can I mount it with the rear wheels on the dolly and and lock the steering wheel in place to tow straight and will the rear wheels be ok to roll on and off the dolly? Thanks, Steve |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Yes, you can pull the splined shaft onto the hub by tightening the nut. I rolled my 914 all over the garage w/o the hub installed before I read that one should not do that. I figured I'd be replacing the new rear wheel bearings within a few hundred miles; again! (IMG:style_emoticons/default/mad.gif) That was 17,000 miles ago and they're still fine. (IMG:style_emoticons/default/confused24.gif) Do I still roll a 914 around w/o the stub axle? Not since I've read not to. Perhaps there are more factors in play? Maybe load factors; installers skill level; properly torqued; were they properly greased at the factory (remember there have been several reports of new bearings with an insufficient amount of grease); contamination for shop debris which entered the "open" bearing, etc., etc. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 07:43 AM |
