billium01 |
Member ![]() ![]() Group: Members Posts: 136 Joined: 12-April 13 Member No.: 15,764 Region Association: None ![]() |
Hello thanks for looking. Gonna replace the front trunk floor pan and the panel that the front bumper attaches too. Restoration designs calls it the "latch panel". On the picture I posted it's panel number 13. Any advice on doing this without a celette bench?
Thanks Bill ![]() ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
You need to hold the car in place somehow.
Build a frame out of tall (in profile) boxed steel, or I beams. Weld stands from that to both sides...so a piece of square tubing the same length from the ibeam to the rear firewall seam. Basically, attach the car, parallel and ideally level to the beam. |
billium01 |
You need to hold the car in place somehow. Build a frame out of tall (in profile) boxed steel, or I beams. Weld stands from that to both sides...so a piece of square tubing the same length from the ibeam to the rear firewall seam. Basically, attach the car, parallel and ideally level to the beam. Thanks! Appreciate it. Ended up buying one of these. Looks like it'll work ok huh? ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 04:08 AM |
