Strut repairs, For the guys trying to keep a factory six original. |
ClayPerrine |
Mar 5 2019, 07:01 AM
Life's been good to me so far..... Group: Admin Posts: 15,967 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Recently, I found the left front strut on Elwood clunking when I moved it. Seems the ball joint was moving in the bottom of the strut. The ball joint setup is the pinch type, and it is too damaged to repair. I wanted to keep it stock. So I talked with the machinist that is helping with the adapter plate for the 4.0. I suggested a sleeve, but that wouldn't leave enough structure on the ball joint. We came up with the idea of replacing the casting in the bottom of the strut with a later wedge pin type strut. Porsche put them on starting in 72 for safety reasons.
So I gave him the two 914-6 struts, and two /4 struts with the wedge type ball joint connections. He was able to remove the ball joint mount from the /4 struts, and put them into the /6 struts. He told me that to remove the old bottoms from the /6 struts, he had to set them up in the lathe and turn them as slowly as possible, and the 4k lb lathe started to hop anyway. The welds looked factory when done, and now Elwood has the updated, safer ball joints in him. So if you find yourself in the same situation, contact Zims Autotechnic at 817-267-4451 and they can fix your factory /6 struts up to use the wedge type ball joints. Sorry for no pictures, mine would have looked just like ball joint replacement picts. Maybe my machinist (he is a member here) can throw some pictures up. |
eeyore |
Mar 5 2019, 12:54 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
Couldn't you have removed the spindle off the -6 tube and slid it onto a -4 tube?
partsguy22 |
Mar 5 2019, 04:37 PM
Enabler of bad ideas Group: Members Posts: 24 Joined: 8-November 17 From: FT Worth, Tx Member No.: 21,587 Region Association: None |
Couldn't you have removed the spindle off the -6 tube and slid it onto a -4 tube? Thats easier said than done My attempt to " Just cut the welds and press 'er off " well... lets just say that didn't work like I wanted it to (hint: there is no good surface to press against on a 914-4 spindle to take it apart ,with out possibly damaging something) Not to mention the way the -4 spindle is welded to the tube is very difficult to cut all the weld out with damaging the tube And I'd also have to cut and transfer the brake line tabs and that would be just way to much work (IMG:style_emoticons/default/biggrin.gif) |
Krieger |
Mar 5 2019, 07:37 PM
Advanced Member Group: Members Posts: 4,771 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
[/quote] Thats easier said than done My attempt to " Just cut the welds and press 'er off " well... lets just say that didn't work like I wanted it to (hint: there is no good surface to press against on a 914-4 spindle to take it apart ,with out possibly damaging something) Not to mention the way the -4 spindle is welded to the tube is very difficult to cut all the weld out with damaging the tube And I'd also have to cut and transfer the brake line tabs and that would be just way to much work (IMG:style_emoticons/default/biggrin.gif) [/quote] I just tried to remove the spindle from a 4 cylinder strut can as well. I had the same exact problems. It did not happen. I was able to remove the spindle off a 6 cylinder can though. The welds are different. |
Lo-Fi Version | Time is now: 6th January 2025 - 03:22 PM |
