Strut repairs, For the guys trying to keep a factory six original. |
ClayPerrine |
Mar 5 2019, 07:01 AM
Life's been good to me so far..... Group: Admin Posts: 15,967 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Recently, I found the left front strut on Elwood clunking when I moved it. Seems the ball joint was moving in the bottom of the strut. The ball joint setup is the pinch type, and it is too damaged to repair. I wanted to keep it stock. So I talked with the machinist that is helping with the adapter plate for the 4.0. I suggested a sleeve, but that wouldn't leave enough structure on the ball joint. We came up with the idea of replacing the casting in the bottom of the strut with a later wedge pin type strut. Porsche put them on starting in 72 for safety reasons.
So I gave him the two 914-6 struts, and two /4 struts with the wedge type ball joint connections. He was able to remove the ball joint mount from the /4 struts, and put them into the /6 struts. He told me that to remove the old bottoms from the /6 struts, he had to set them up in the lathe and turn them as slowly as possible, and the 4k lb lathe started to hop anyway. The welds looked factory when done, and now Elwood has the updated, safer ball joints in him. So if you find yourself in the same situation, contact Zims Autotechnic at 817-267-4451 and they can fix your factory /6 struts up to use the wedge type ball joints. Sorry for no pictures, mine would have looked just like ball joint replacement picts. Maybe my machinist (he is a member here) can throw some pictures up. |
sixnotfour |
Mar 5 2019, 01:18 PM
914 Wizard Group: Members Posts: 10,698 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
yes but pn is important
ClayPerrine |
Mar 5 2019, 02:15 PM
yes but pn is important That's why we replaced the ball joint mount in the spindle. The strut still has the original 914 part number on it. This applies to all 911 and 914 models through 1971. The 1972 models came with the wedge ball joints. We even discussed making a wedge pin that has a bolt head on it so it looks like the pinch type setup. |
mepstein |
Mar 6 2019, 10:41 AM
914-6 GT in waiting Group: Members Posts: 19,684 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
yes but pn is important That's why we replaced the ball joint mount in the spindle. The strut still has the original 914 part number on it. This applies to all 911 and 914 models through 1971. The 1972 models came with the wedge ball joints. We even discussed making a wedge pin that has a bolt head on it so it looks like the pinch type setup. So it’s important to have an original part number on a non original part because ??? (IMG:style_emoticons/default/poke.gif) |
ClayPerrine |
Mar 6 2019, 11:15 AM
yes but pn is important That's why we replaced the ball joint mount in the spindle. The strut still has the original 914 part number on it. This applies to all 911 and 914 models through 1971. The 1972 models came with the wedge ball joints. We even discussed making a wedge pin that has a bolt head on it so it looks like the pinch type setup. So it’s important to have an original part number on a non original part because ??? (IMG:style_emoticons/default/poke.gif) The majority of the part is original. The only reason I had the ball joint type changed was for safety reasons. And our objective for the car is to keep it as original as possible. |
Lo-Fi Version | Time is now: 6th January 2025 - 03:37 PM |
