> Strut repairs, For the guys trying to keep a factory six original.
ClayPerrine
post Mar 5 2019, 07:01 AM
Recently, I found the left front strut on Elwood clunking when I moved it. Seems the ball joint was moving in the bottom of the strut. The ball joint setup is the pinch type, and it is too damaged to repair. I wanted to keep it stock. So I talked with the machinist that is helping with the adapter plate for the 4.0. I suggested a sleeve, but that wouldn't leave enough structure on the ball joint. We came up with the idea of replacing the casting in the bottom of the strut with a later wedge pin type strut. Porsche put them on starting in 72 for safety reasons.
So I gave him the two 914-6 struts, and two /4 struts with the wedge type ball joint connections. He was able to remove the ball joint mount from the /4 struts, and put them into the /6 struts. He told me that to remove the old bottoms from the /6 struts, he had to set them up in the lathe and turn them as slowly as possible, and the 4k lb lathe started to hop anyway.
The welds looked factory when done, and now Elwood has the updated, safer ball joints in him.
So if you find yourself in the same situation, contact Zims Autotechnic at 817-267-4451 and they can fix your factory /6 struts up to use the wedge type ball joints.
Sorry for no pictures, mine would have looked just like ball joint replacement picts.
Maybe my machinist (he is a member here) can throw some pictures up.
eeyore
post Mar 5 2019, 12:54 PM
Couldn't you have removed the spindle off the -6 tube and slid it onto a -4 tube?
partsguy22
post Mar 5 2019, 04:37 PM
Enabler of bad ideas
QUOTE(eeyore @ Mar 5 2019, 12:54 PM) *
Thats easier said than done
My attempt to " Just cut the welds and press 'er off " well... lets just say that didn't work like I wanted it to
(hint: there is no good surface to press against on a 914-4 spindle to take it apart ,with out possibly damaging something)
Not to mention the way the -4 spindle is welded to the tube is very difficult to cut all the weld out with damaging the tube
And I'd also have to cut and transfer the brake line tabs and that would be just way to much work (IMG:style_emoticons/default/biggrin.gif)
Dave_Darling
post Mar 6 2019, 05:12 PM
914 Idiot
QUOTE(partsguy22 @ Mar 5 2019, 02:37 PM) *
Thats easier said than done ...
Well, just do about 40 track days and/or autocrosses per year for ~40 years, and they'll come off.
Or maybe you have to be Terry Zaccone for that to happen...
(It was very strange to see the whole hub and spindle fly off the car and bounce across the autoX site!)
--DD
ClayPerrine   Strut repairs   Mar 5 2019, 07:01 AM
partsguy22   Thanks Clay I didn't take many pictures of th...   Mar 5 2019, 09:29 AM
partsguy22   I am also working on making new wedge bolt strut b...   Mar 5 2019, 09:41 AM
eeyore   Couldn't you have removed the spindle off the ...   Mar 5 2019, 12:54 PM
partsguy22   Couldn't you have removed the spindle off the...   Mar 5 2019, 04:37 PM
Krieger   Thats easier said than done My attempt to ...   Mar 5 2019, 07:37 PM
ClayPerrine   Couldn't you have removed the spindle off th...   Mar 6 2019, 09:41 AM
Dave_Darling   Couldn't you have removed the spindle off th...   Mar 6 2019, 05:12 PM
mskala   Couldn't you have removed the spindle off the...   Mar 6 2019, 09:56 AM
sixnotfour   yes but pn is important   Mar 5 2019, 01:18 PM
ClayPerrine   yes but pn is important That's why we repl...   Mar 5 2019, 02:15 PM
mepstein   yes but pn is important That's why we rep...   Mar 6 2019, 10:41 AM
ClayPerrine   [quote name='ClayPerrine' post='2694352' date='Ma...   Mar 6 2019, 11:15 AM
mepstein   [quote name='ClayPerrine' post='2694352' date='M...   Mar 6 2019, 02:07 PM
partsguy22   So it’s important to have an original part numb...   Mar 6 2019, 11:33 AM
dr914@autoatlanta.com   some people have all of the skill!   Mar 5 2019, 01:21 PM
dr914@autoatlanta.com   funny but we have at least 16 nos RIGHT front 914-...   Mar 5 2019, 03:04 PM
ClayPerrine   funny but we have at least 16 nos RIGHT front 914...   Mar 5 2019, 03:41 PM
Mark Henry   :thumbsup: Marky approved! :D   Mar 5 2019, 05:18 PM
Mark Henry   Not just for 914/6, I have two 914's with 914/...   Mar 6 2019, 09:57 AM
toolguy   be sure to refinish them in the correct gray color...   Mar 6 2019, 12:12 PM
ClayPerrine   be sure to refinish them in the correct gray colo...   Mar 6 2019, 02:14 PM
rgalla9146   be sure to refinish them in the correct gray colo...   Mar 6 2019, 06:30 PM
Rob-O   So it’s important to have an original part num...   Mar 8 2019, 10:29 AM
partsguy22   [quote name='partsguy22' post='2694616' date='Mar...   Mar 12 2019, 10:07 AM
sixnotfour   been cutting off wedge ends , every pair of 4lug s...   Mar 8 2019, 10:47 AM
bdstone914   @nacho   Mar 12 2019, 10:54 PM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 03:44 PM
