Firewall Shift rod hole, This doesn't look right |
BPic |
Mar 9 2019, 11:37 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I'm working on the engine bay and noticed something didn't look quite right with the shift rod hole in the firewall.
I plan on using the Tangerine shift rod bearing but the firewall hole protrudes out not in. Do I need to add another ring to it? (IMG:style_emoticons/default/confused24.gif) This is the Tangerine Bearing Thanks everyone. |
jimkelly |
Mar 9 2019, 04:20 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
1 white 1975
2 orange 1972 of area depending on the OD of the hole in your firewall, you may have enough meat left to rivet the tangerine busing on place, but that circular lip will be in your way, either way, it seems. if not, you'll have to grind of that lip and weld in (or rivet in) a piece of flat steel with an OD small enough for you to provide the 3 holes needed for riveting it in i guess. also, i have one, not yet installed. it seems to have to be installed in a specific direction. http://www.tangerineracing.com/transmission.htm Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 21st September 2024 - 07:04 PM |
