Source of bronze bushing for side shift transmission console, 914 424 224 02 |
carl k |
Mar 11 2019, 12:43 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
Who carries the bronze replacement bushing kit for the shift console? The only place I've found it is Patrick Motorsports and they want almost $20 to ship the $25 part.
thanks! Carl |
johnhora |
Mar 11 2019, 01:50 PM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Why do you want or think you need the brass one?
carl k |
Mar 11 2019, 07:36 PM
I installed a new bushing kit from one of our 914World members. Even with a new plastic bushing, I am seeing 0.074" of radial play (a combination of bushing loose in housing and clearance between bushing and shift rod.)
Maybe that's normal? The shift rod is constant diameter over it's length, so I don't think it's worn just at the bushing location. I have to remove the engine for other reasons, so thought I'd investigate the bronze bushing. regards, Carl Why do you want or think you need the brass one? |
michael7810 |
Mar 12 2019, 09:35 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I installed a new bushing kit from one of our 914World members. Even with a new plastic bushing, I am seeing 0.074" of radial play (a combination of bushing loose in housing and clearance between bushing and shift rod.) Maybe that's normal? The shift rod is constant diameter over it's length, so I don't think it's worn just at the bushing location. I have to remove the engine for other reasons, so thought I'd investigate the bronze bushing. regards, Carl Why do you want or think you need the brass one? On mine, the new plastic bushing was also loose in the console so I shimmed it with a single wrap of aluminum from a La Croix can and now it’s tight in the console and on the shift rod. It really made a difference shifting into first. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:43 PM |
