How do I....?, I need to create a "switched" ciruit |
Carlitos Way |
Nov 26 2004, 02:16 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
For some unknown reason, the PO had run the fuel pump off the Tail Light circuit, so I need to correct this. I tried other fuses in the fuse box, but they all seem to be either on all the time, or only on when specific things are turned on. So I decided to do things "better."
I would like to run a "switched" circuit to my fuse box, so I can have the fuel pump active only when the engine is running (ignition in the ON position?). I have upgraded to the 15 fuse box and would like to create two new switched fuse circuits for my fuel pump and my stereo (one each), that way I can get ahead of the game, and know exactly where everything is, rather than splicing more stuff and screwing around with the electrical system. Can you help/offer any suggestions? |
TheCabinetmaker |
Nov 26 2004, 05:10 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The power for the pump comes from the #13 pin on the 14 pin connector on the relay board. There are two fuses on the relay board. IIRC the rear one is for the fuel pump, and one of the black round relays also controls it. There are some other folks here who can splain it lots better than me. Can anyone help us out?
Lo-Fi Version | Time is now: 26th June 2024 - 03:39 AM |
