How do I....?, I need to create a "switched" ciruit |
Carlitos Way |
Nov 26 2004, 02:16 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
For some unknown reason, the PO had run the fuel pump off the Tail Light circuit, so I need to correct this. I tried other fuses in the fuse box, but they all seem to be either on all the time, or only on when specific things are turned on. So I decided to do things "better."
I would like to run a "switched" circuit to my fuse box, so I can have the fuel pump active only when the engine is running (ignition in the ON position?). I have upgraded to the 15 fuse box and would like to create two new switched fuse circuits for my fuel pump and my stereo (one each), that way I can get ahead of the game, and know exactly where everything is, rather than splicing more stuff and screwing around with the electrical system. Can you help/offer any suggestions? |
Carlitos Way |
Nov 26 2004, 05:49 PM
thanks for your response...
To answer your question... I didn't jumper it... the PO had relocated it, but he dragged the wire connection from the brake fuse. So, every time I step on the brake the car dies. Still trying to figure out where to wire it from. I don't mind creating a dedicated circuit for it... I just wish I knew how. Otherwise.. can I run a jumper from the red/black wire to the fuel pump and have it only kick in with the ignition in the ON position? C. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:41 AM |
