> 1973 2.0L Rustoration, Restoration turned OT garage build
Superhawk996
post Dec 21 2018, 04:10 PM
I purchased my first 914 back in 1987 (1973 1.7L) and had that car for nearly a decade and I personally put over 100,000 miles on it before it ultimately fell victim to a negligent driver that drove into the back end of it at about 40 mph while the vehicle was stopped at a red light. That rear end crash totaled the vehicle but what is amazing is how well it crumpled (early crush zones!) due to the kink in the frame where the halfshafts are. Everyone walked away unharmed.
I replaced it with a 1991 Miata. Great car in its own right but I've always missed my 914.
Purchased this "replacement" in May 2018 as a known poster child for a complete right side longitudinal rustoration.
This vehicle had been put into storage inside a pole barn around 2004 as far as I can tell.
Vehicle initially purchased in non-running condition:
Engine couldn't be started.
Transmission shift linkage was disconnected
Half shafts and CV's were in pieces, and the wheel stubs were not installed therefore the vehicle couldn't even be rolled without risking having the rear wheel separate from within the bearing.
Fiberglass laid into the floorpan . . . that can't be a good sign.
Vehicle looks great . . . until I got under it.
I spent the better part of the summer putting the items above back together and trying to confirm that it would:
1) Run under its own power
2) Drive though the neighborhood and shift though all gears.
Looks pretty nice eh?
Here is what is lurking underneath once the rockers came off.
and when I started cutting back the rust. Oh my . . . .
Superhawk996
post Mar 15 2019, 10:08 PM
Although I had a rough mock up there is still more work to do on the wheelhouse inner panel.
I finally decided to commit to final welding of the outer trailing arm mount.
I plan to add the Restoration Design outer clam shell to reinforce the whole outer longitudinal.
The problem is I'm not cutting my fender so all work has to be done from the "inside". This means that I can't assemble the whole longitudinal and then go back and add on the clam shell.
Much scratching of the head (IMG:style_emoticons/default/idea.gif) resulted in the decision to deconstruct the clam shell so that it can be added in pieces rather than one whole piece. The other thing is I don't like how the added layer of metal will push my existing door jamb outboard. I'll try to post picture of this as I go along. Hopefully the pictures will make things more obvious.
Here is the picture of just the rear section of the clam shell reinforcement in place. I feel that this piece is especially important since it adds another layer of metal to the transition area. This area where a lot of stress occurs and this area of the "frame" is weak since this area is where the inner longitudinal panels meet.
Even if I decide later not to add the rest of the clamshell for some unforseen reason, I feel that having a triple layer in this high stress area is time well spent.
You can see the overlay for the jack post with the spot welds drilled in the background. I'll eventually install that but it needs some trimming to avoid pushing out the door jamb.
Welded in place.
In the process of final welding I did get some warping of the panel that needed hammer and dolly work to put things back in the right place so the inner longitudinal in the engine compartment will fit as it originally did.
Likewise, this will require re-measurement all the way around the chassis again before I can put this panel in place for the final fitment.
During this whole process the Galvanneal steel is giving me fits with a TIG welder. (IMG:style_emoticons/default/headbang.gif)
The zinc that is in the Galvanneal is constantly contaminating the electrode or causing popping that splashes the weld puddle up onto it.
The only good thing is the constant stop / start to regrind the Tungsten helps avoid overheating the panel. (IMG:style_emoticons/default/dry.gif)
Superhawk996   1973 2.0L Rustoration   Dec 21 2018, 04:10 PM
Superhawk996   With a new found 914 where else would I go but to ...   Dec 21 2018, 05:26 PM
Cairo94507   :wttc: Well you found the best place in the world ...   Dec 21 2018, 06:45 PM
Superhawk996   In the process, I also fabricated up some door bra...   Dec 21 2018, 06:52 PM
Superhawk996   At this point, it became clear that there would be...   Dec 21 2018, 07:01 PM
Superhawk996   This project started with a few goals in mind: 1)...   Dec 21 2018, 07:11 PM
Superhawk996   Alright, so now is probably a good time to plug a ...   Dec 21 2018, 08:07 PM
Jamie   You obviously know how to weld and have the tools,...   Dec 21 2018, 08:24 PM
Superhawk996   So what are the skeletons on this car that I'v...   Dec 21 2018, 08:25 PM
Dave_Darling   I'm trying to figure out a better way to do t...   Dec 21 2018, 08:54 PM
Superhawk996   How about this one? Mileage on the ODO is 60K (is...   Dec 21 2018, 08:33 PM
Superhawk996   All new vintage vehicle acquisitions come with sur...   Dec 21 2018, 08:43 PM
Superhawk996   This was another favorite. Some sort of home made...   Dec 21 2018, 08:55 PM
Superhawk996   Also found the driver side suspension console to h...   Dec 21 2018, 09:08 PM
Superhawk996   All right, one last fun post for the evening. I...   Dec 21 2018, 09:31 PM
euro911   I really enjoy reading these kinds of brutal rusto...   Dec 22 2018, 06:04 AM
76-914   That fiberglass added 40 lb's to the car. I al...   Dec 22 2018, 08:51 AM
bbrock   :wttc: Anyone crazy enough to save a rusted out ba...   Dec 22 2018, 09:40 AM
Superhawk996   Thank you for the kind words of encouragement...   Dec 23 2018, 02:25 PM
Superhawk996   Overall pretty happy with progress so far. Floo...   Dec 23 2018, 10:05 PM
bbrock   Then put passenger side door back on to gauge doo...   Dec 23 2018, 11:03 PM
Superhawk996   Then put passenger side door back on to gauge do...   Dec 23 2018, 11:22 PM
bbrock   That was the 1st time for me with pulling my back...   Dec 23 2018, 11:37 PM
jmitro   Alternatively, if you look carefully, you may fin...   Dec 29 2018, 09:51 PM
Superhawk996   Also did some more removal of the rear frame ...   Dec 23 2018, 10:32 PM
Superhawk996   So after all that, I decided to take a look at how...   Dec 23 2018, 10:42 PM
sixnotfour   way to dive in... :wttc: :first:   Dec 23 2018, 10:46 PM
Superhawk996   So here is a fun picture of my original 914 back i...   Dec 23 2018, 11:53 PM
whitetwinturbo   ............I'm popped out just reading this t...   Dec 27 2018, 12:00 AM
Superhawk996   Getting back to work after a few days off. Slow...   Dec 29 2018, 09:02 PM
Superhawk996   Posted a video up on YouTube. Posted as much for ...   Dec 29 2018, 09:31 PM
Superhawk996   Deleted duplicate post - oops!   Dec 29 2018, 09:34 PM
Superhawk996   Spent a bit of time getting the 914 clock working....   Jan 1 2019, 12:08 PM
bbrock   Happy New Year! Thanks for posting your clock...   Jan 1 2019, 01:41 PM
Superhawk996   I'm curious about the thermal fuse. Is the...   Jan 1 2019, 02:42 PM
euro911   Is there enough room inside the housing to solder ...   Jan 1 2019, 03:24 PM
bbrock   Littlefuse also has miniature ceramic fuses with ...   Jan 1 2019, 06:42 PM
Dion   Just spotted this thread. Nice work! & Go...   Jan 1 2019, 06:25 PM
Superhawk996   I suppose you could add in one of those miniature ...   Jan 3 2019, 07:58 PM
FourBlades   Great looking restoration! Check out this pag...   Jan 4 2019, 08:40 AM
Superhawk996   Great looking restoration! Check out this pa...   Jan 19 2019, 11:35 AM
bbrock   Thanks for the details on the clock. Makes sense ...   Jan 4 2019, 08:49 AM
Superhawk996   Happy to be of help! I ordered some special...   Jan 5 2019, 05:59 PM
Superhawk996   Didn't get much done that looks impressive. ...   Jan 5 2019, 06:07 PM
Superhawk996   Have not posted in a while but I've been worki...   Jan 19 2019, 12:08 PM
Superhawk996   The trailing arm mount on my car came with one of ...   Jan 19 2019, 12:34 PM
euro911   I drill two holes in the bottom of each jack point...   Jan 19 2019, 04:44 PM
Superhawk996   I drill two holes in the bottom of each jack poin...   Jan 26 2019, 10:11 AM
Superhawk996   :headbang: Having a rough go of getting the trai...   Jan 26 2019, 10:32 AM
Superhawk996   Also picked up some front brake calibers from PMB ...   Jan 26 2019, 10:47 AM
Superhawk996   Update on the trailing arm mount madness: Laser p...   Jan 30 2019, 09:59 AM
Superhawk996   Back to work. Last couple of weekends have been l...   Feb 9 2019, 06:24 PM
mgphoto   I bought the same part through Sierra Madre col...   Mar 17 2019, 10:11 AM
R8CERX   WOW--AWESOME work!! :cheer: Cant wait to ...   Mar 1 2019, 02:19 PM
Superhawk996   It's been a while since I posted. Things have...   Mar 15 2019, 09:45 PM
Superhawk996   Although I had a rough mock up there is still more...   Mar 15 2019, 10:08 PM
Superhawk996   The other thing that has derailed my effort to get...   Mar 15 2019, 10:19 PM
bbrock   But the more I got to thinking about doing a from...   Mar 15 2019, 10:41 PM
Superhawk996   @porscheaddic Came to my rescue and provided a ...   Mar 15 2019, 10:32 PM
Superhawk996   I'll end up with some odds and ends that I won...   Mar 15 2019, 10:37 PM
Superhawk996   @bbrock You've set a pretty high bar. I...   Mar 15 2019, 10:44 PM
Superhawk996   @mgphoto :headbanger: Nice project photo. I ...   Mar 17 2019, 10:20 AM
mgphoto   I would like to see a photo of your car sort of th...   Mar 17 2019, 10:41 AM
Superhawk996   I would like to see a photo of your car sort of t...   Mar 17 2019, 11:42 AM
bbrock   My thought is the 2nd hole might have something ...   Mar 17 2019, 12:20 PM
mgphoto   [quote name='mgphoto' post='2697526' date='Mar 17...   Mar 20 2019, 11:54 AM
Superhawk996   Photo of passenger side donor sheet metal rough tr...   Mar 17 2019, 11:45 AM
Superhawk996   Time to post a little progress for March. Here ...   Apr 6 2019, 04:17 PM
bbrock   Just your mark-up is a work of art. That's qu...   Apr 6 2019, 06:02 PM
Superhawk996   Just your mark-up is a work of art. That's q...   Apr 6 2019, 06:26 PM
Superhawk996   I was saving my effort doing complex metal forming...   Apr 6 2019, 06:35 PM
Superhawk996   Been a little bit slow posting lately. Spring and...   Apr 23 2019, 07:31 AM
Superhawk996   This cowl area has taken way too much time. A f...   Apr 23 2019, 07:52 AM
Superhawk996   The other thing that led to rushing the job was al...   Apr 23 2019, 08:15 AM
tygaboy   :agree: with all the "can't see = can...   Apr 23 2019, 08:32 AM
Superhawk996   :agree: with all the "can't see = can...   Apr 23 2019, 08:48 AM
Superhawk996   These are the easy ones. Just a quick dab or two ...   Apr 23 2019, 08:35 AM
Superhawk996   The other work that has started in April is beginn...   Apr 23 2019, 09:04 AM
Superhawk996   Here is a bit of previous work. I removed the tun...   Apr 23 2019, 09:27 AM
Superhawk996   For all you guys that think just a little rust in ...   Apr 23 2019, 09:34 AM
Dave_Darling   Would a copper backer help with the blow-through i...   Apr 23 2019, 12:05 PM
Superhawk996   Would a copper backer help with the blow-through ...   Apr 23 2019, 02:02 PM
Superhawk996   Well since I'm not supposed to be doing any he...   Apr 28 2019, 04:49 PM
Dave_Darling   Worse than the rust debris / garbage there is som...   Apr 28 2019, 07:02 PM
bbrock   Worse than the rust debris / garbage there is so...   Apr 28 2019, 07:31 PM
restore2seater   I have no idea what this is or where it came from....   Apr 29 2019, 08:04 AM
Superhawk996   On a more positive note. Most of the other engine...   Apr 28 2019, 05:03 PM
bbrock   When I rebuilt my short block, I filled all the ga...   Apr 28 2019, 05:13 PM
Superhawk996   I've gotta admit JB weld is pretty good at res...   Apr 28 2019, 05:24 PM
Superhawk996   Here is the Miata in it's prime as a MUV. Mia...   Apr 28 2019, 05:27 PM
bbrock   Here is the Miata in it's prime as a MUV. Mi...   Apr 28 2019, 05:57 PM
Superhawk996   @bbrock Wait a few years, but, you definitely sh...   Apr 28 2019, 06:12 PM
Superhawk996   Here's a video of the posted Miata turning 220...   Apr 28 2019, 06:18 PM
bbrock   Here's a video of the posted Miata turning 22...   Apr 28 2019, 07:36 PM
Tenner   A few posts earlier, you've been talked about ...   Apr 29 2019, 02:55 AM
injunmort   to fill pits in rocker covers, try boiler cement. ...   Apr 29 2019, 04:33 AM
Superhawk996   @Tenner [b]Looks like nice work. You most defin...   Apr 29 2019, 04:44 AM
bbrock   @[url=http://www.914world.com/bbs2/index.php?show...   Apr 29 2019, 08:11 AM
injunmort   brake piston   Apr 29 2019, 10:18 AM
Superhawk996   brake piston Good guess . . . but it would ha...   Apr 29 2019, 11:40 AM
6 Pages V  1 2 3 > »
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th April 2025 - 02:20 AM
