Boxster Calipers, got them installed today! |
SirAndy |
Feb 27 2012, 01:12 AM
Resident German Group: Admin Posts: 41,892 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
About time too as my Carrera brake pads were down to the metal.
The idea was simple, get rid of the Carrera Calipers and mount Boxster Calipers all around using the mounting adapters from Rich Johnson. Of course, nothing ever goes as planned: (IMG:style_emoticons/default/headbang.gif) First, i failed to read Rich's instructions that clearly state that you have to use a 20mm 911 SC rear rotor. Well, i have 24mm Carrera rear rotors. The Boxster Calipers had to be machined (2mm off each of the brake pad pins) and the adapters had to be milled to center the Boxster Calipers over the wider rotors. (IMG:style_emoticons/default/smash.gif) Then, after everything was bolted together, i recalled reading that the hard brake lines may not be long enough. And sure enough (of course) the front brake lines were about 1" too short. Arrghhh. (IMG:style_emoticons/default/rolleyes.gif) McMark came to the rescue and we made two new lines. (IMG:style_emoticons/default/thumb3d.gif) In the rear, i used banjo fittings on the Calipers (Thanks to Eric Shea for those!) and the rear brakelines were no problem. Mark and i then bled the brakes. I was still getting some air in the front, but it was already 9pm so we decided to call it a night and i drove it home (40+ miles). The brakes actually felt fine, they seem to work great. I'll go back to the OC shop next weekend and we'll bleed them again. (IMG:style_emoticons/default/driving.gif) And now for the pitchers: (IMG:style_emoticons/default/beer3.gif) |
Luke M |
Aug 30 2013, 05:38 PM
Senior Member Group: Members Posts: 1,394 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
From the Pelican site.
http://www.pelicanparts.com/catalog/shopca..._BRKprf_pg1.htm The part numbers for the Boxster calipers required for this kit: Front left: 986-351-421-03 Front right: 986-351-422-03 Rear left: 986-352-423-01 Rear right: 986-352-424-01 The part numbers for the brake rotors required for this kit: Front Carrera: 911-351-041-22 Rear 911SC: 901-352-041-14 The part numbers for the brake pads required for this kit: Front: 986-351-939-15 Rear: 986-352-939-10 |
amallagh |
Mar 17 2019, 06:58 PM
Member Group: Members Posts: 103 Joined: 4-September 06 From: Cheshire, England Member No.: 6,767 |
What happens if you use the 996 part number rear calipers (still non S) ?
i.e. part numbers 996 352 421 & 996 352 422, (rather than 986-352-423-01 & 986-352-424-01 as stated below) ? I see Luke asked this question way back then but I don't see an answer. ( I have some of these 996 part number rear calipers and need to know if I can use the adaptors and whether to use SC 20mm rotors or 24mm Carrera ones on the rear. Regards Andrew From the Pelican site. http://www.pelicanparts.com/catalog/shopca..._BRKprf_pg1.htm The part numbers for the Boxster calipers required for this kit: Front left: 986-351-421-03 Front right: 986-351-422-03 Rear left: 986-352-423-01 Rear right: 986-352-424-01 The part numbers for the brake rotors required for this kit: Front Carrera: 911-351-041-22 Rear 911SC: 901-352-041-14 The part numbers for the brake pads required for this kit: Front: 986-351-939-15 Rear: 986-352-939-10 |
Lo-Fi Version | Time is now: 24th November 2024 - 04:43 PM |
