Alfafan |
Newbie ![]() Group: Members Posts: 5 Joined: 26-March 19 From: Los Angeles Member No.: 22,993 Region Association: Southern California ![]() |
Hi All,
I'm looking into the purchase of a '73 2.0L and have the car at a local specialist shop for a PPI. The car has a recent engine rebuild with about 500 miles since. It runs well with the only exceptions that it surges and falls a bit at idle (I wasn't too concerned about that), but the compression test readings that were just relayed back to me are a concern. The compression readings are 110, 110, 110 and 120psi. Would these numbers be in the normal range for a fresh engine? They seem low to me. I'm waiting for a call from the mechanic with the particulars including confirming how the test was done (hot engine, thottle wide open, plugs out...etc?). Assuming the test was done correctly, would these values point to a problem? Is it possible that the engine is not fully broken in and the readings would be expected to rise? Thanks for your help! |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
How were those 500 miles accumulated? Maybe the rings haven't fully seated yet?
(IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 05:26 AM |
