ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
Overview
'74 2.0L, 20K miles, stored since '84, first run Oct 2018. 100% stock D-Jet engine with new hoses, fuel system, etc. Spec compression on all 4. Dwell set, timing set. Engine runs good, strong - chasing idle problems (see my post 'idle weirdness'). My question is; how good can I get this engine to idle? Can this engine run smooth at 800-900 RPM with very little engine vibration? Can the engine run rock steady at 800 rpm without minor surges? Currently this engine is shaking at idle, not violently but you can feel it in the cab. Does anyone have a high quality audio example of this engine running when new? Or to absolute factory spec? (yea, I know many of you believe that this is not a good method of reference, but hearing what one SHOULD sound like is helpful). I look forward to coming into this group of like minded 914-crazy (me being the most crazy) group of awesome people each day. Many thanks in advance CTC911CTC |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Also consider looking at the engine wiring harness.
I ended up making one good as new wiring harness out of 3 old ones. Many of the wires had become brittle and had broken insulation under the protective sleeves. This made a huge improvement in how smooth the engine ran (1.7L D-Jet). (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:44 AM |
