ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
Overview
'74 2.0L, 20K miles, stored since '84, first run Oct 2018. 100% stock D-Jet engine with new hoses, fuel system, etc. Spec compression on all 4. Dwell set, timing set. Engine runs good, strong - chasing idle problems (see my post 'idle weirdness'). My question is; how good can I get this engine to idle? Can this engine run smooth at 800-900 RPM with very little engine vibration? Can the engine run rock steady at 800 rpm without minor surges? Currently this engine is shaking at idle, not violently but you can feel it in the cab. Does anyone have a high quality audio example of this engine running when new? Or to absolute factory spec? (yea, I know many of you believe that this is not a good method of reference, but hearing what one SHOULD sound like is helpful). I look forward to coming into this group of like minded 914-crazy (me being the most crazy) group of awesome people each day. Many thanks in advance CTC911CTC |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,993 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
idle will never compare to modern vehicle standard. You will always feel idle to some degree on a 914; even with a smoother running six cylinder engine.
There is very little isolation from engine and/or transmission mounts by modern standards. Modern vehicle idle is a careful tuning of engine firing order vs. engine mount damping characteristics. Many modern vehicles use active engine mounts that are tuned to one frequency at idle and another frequency at road speed. 914 has no such thing just two tiny engine mounts that are a couple of inches in diameter. Cannot compare vintage cars to modern. Enjoy what you have. |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
idle will never compare to modern vehicle standard. You will always feel idle to some degree on a 914; even with a smoother running six cylinder engine. (IMG:style_emoticons/default/agree.gif) BUT...you can get it pretty close. Modern cars use a closed-loop FI system, and the computer and idle air control valve can compensate for the different variables. D-Jet has no feedback mechanism other than you making the necessary tuning changes based on what you see/hear/experience. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:47 AM |
