LED Foglight Project |
Spoke |
Apr 13 2019, 08:45 AM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. This is the spectral dispersion for the lens. |
StratPlayer |
Apr 13 2019, 01:34 PM
StratPlayer Group: Members Posts: 3,299 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Will you be making these for the rectangle style fog lights?
Spoke |
Apr 14 2019, 05:57 AM
Will you be making these for the rectangle style fog lights? Once the round board is proved out, yes I plan to migrate to the rectangle style. Also want to do a rectangle style for the 911. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 21st December 2024 - 08:00 AM |
