LED Foglight Project |
Spoke |
Apr 13 2019, 08:45 AM
Jerry Group: Members Posts: 7,106 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The design of an early foglight LED board has begun. mepstein sent me a couple of foglight fixtures to use to design the board. 2 main issues are fitment and heat dissipation. If things work out ok the design should be able to be re-laid out for the later square foglight.
The board will have 8 Cree XP-G3 high power surface mount LEDs with 350ma current each. These will burn about 1W of power with a total power dissipation expected to be less than 10W. Hopefully these will be almost as bright as a headlight. Each LED will have its own focusing lens. The lenses are Carclo 10192 elliptical 20mm lenses. The light pattern for the 10192 lens is shown below. This is the spectral dispersion for the lens. |
Spoke |
Apr 22 2019, 06:59 PM
To reduce component and assembly cost, I'm looking for modules to do the 12V-to-constant-current conversion. I found this one from LEDsupply up in Vermont. It looks like it has all the features (12V input) and 350mA output. The package is only 0.83x0.83x0.43 inch. The one downside is the maximum operating temperature is 85C. It might be high enough temperature. Won't know until I build up a board.
PCBs are out of the fab and in shipping. Also ordered all other components. Should be able to do some assembly next week or the week after. Attached image(s) |
Lo-Fi Version | Time is now: 30th December 2024 - 10:19 AM |
