it would appear that I'm not getting fuel out the injectors |
Downerman |
Apr 26 2019, 03:17 PM
Member Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None |
Can't make an injector squirt. Was trying the cold start valve and then read where it had to be cold...like real cold for California as it in the high 80's today and I see it's also connected to a temp sensor so it's no wonder why that was not squirting on start. I was thinking of it as a prime of sorts for a engine cold start.
Anyway I digress. The overall problem is I crank and nothing. I smell some fuel but no leaks. Ignition was testing using Pelican parts protocol and it all checked out. As soon as the wife get's back I will actually pull a plug and see for myself at the plug but it would seem all is well there so I'm looking at fuel. MPS ohm'd out and has tangerines new diaphragm in it. I pulled an injector and checked voltage at the 2 wire plug with the starter blazing away and I got minimal voltage. I believe it was under a volt. What should that be? Can I check the injector by applying a 12V supply to the two pins? It ohm'd out at 2.5 For the record, I primed the fuel system my applying 12V to the pump for a minute. I'm at 31 not 28 based on others who have a slightly larger displacement and that's spot on. My old problem of no 1.5 burst of the fuel pump has been fixed with another ECU. So, when that 1.5 second burst happens does it also open the injectors and prime the cylinders? So close and yet so far. Dave |
Spoke |
Apr 27 2019, 01:00 PM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I pulled an injector and checked voltage at the 2 wire plug with the starter blazing away and I got minimal voltage. I believe it was under a volt. What should that be? As mentioned previously, the voltage to the injector is a pulse so a voltmeter reading DC volts will average the voltage it reads. Back to calculus class, a pulse averaged out over the period will be: VDC = Vpulse * TON/TOFF. Vpulse = 12V and time on (TON) is like 10ms. Time off (TOFF) is like 100ms which is the rotating of the engine. So you should expect to measure VDC = 12 * 10/100 = 1.2V. Your measurement is not that far off. To check injectors, pull an injector and place it in a jar and crank the engine. You should see squirts happening. To check that it's fuel, spray some starting fluid in the intake. If the engine fires then dies, it's fuel. If the engine doesn't fire, it's spark. |
worn |
Apr 27 2019, 01:30 PM
can't remember Group: Members Posts: 3,187 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Also. At a quiet time, turn the key to ignition on. Then slowly press the gas pedal to the floor. As I recall, you should hear 5 injector clicks. I got that one from the Hussey 700 tips book. A good source for a lot of things 914. |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:06 PM |
