'72 914 Power train swap, Removing V8, installing a .... |
jb6000 |
Apr 24 2019, 01:45 PM
Member Group: Members Posts: 52 Joined: 15-September 18 From: Ca Member No.: 22,486 Region Association: None |
Right now this car is a running 1972 914 with a 901 trans converted side shift, and a 350 SBC V8.
Salvage title car, registered etc. Calif. BMW 320 calipers up front. Renegade conversion. So there are many engines that work good in a 914. The stock 914 4 cyl is about 180 pounds. (I am not sure if that is bare long block or dressed motor complete.) The iron V8 with iron heads is about 525 pounds complete. I have a motor that is a 4 cyl. that is 225 pounds long block and about 330 pounds dressed with a turbo. It can put out 300-500 hp with equally high torque. I have a 6 spd transaxle that adds a bit of weight but is far better. So why is this 1.8 liter engine so much stronger than the original Porsche 914 1.8 liter engine? The picture on the top is the naturally aspirated 914 head, the picture below that is the new engine's with a turbo force fed head. Yamaha was in on the creation of this head. "An engine's power is limited by how much air can flow in and out of it." Roughly quoted from some smart guy. This engine has more valves than the Chevy V8. Attached image(s) |
jb6000 |
Apr 27 2019, 01:47 PM
What I have:
Car Water cooling in place Engine Transaxle Shifter Cables Cable mounting bits on transaxle What I don't have yet: Fuel pump ECU Axles Front motor mount Rear transaxle mount Exhaust Intercooler GT28 turbo Chip Injectors Hyd. Clutch pedal (not doing FBW throttle) Goal 280 HP running car. 20 lbs boost at max. Not changing dash or steering wheel. |
Andyrew |
Apr 27 2019, 07:59 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
What I have: Car Water cooling in place Engine Transaxle Shifter Cables Cable mounting bits on transaxle What I don't have yet: Fuel pump ECU Axles Front motor mount Rear transaxle mount Exhaust Intercooler GT28 turbo Chip Injectors Hyd. Clutch pedal (not doing FBW throttle) Goal 280 HP running car. 20 lbs boost at max. Not changing dash or steering wheel. Fuel pump: I recommend a bosch 044 in a surge tank. I put mine in front of the motor. Way more fuel than you need. You can run a cheep chineese version with that much power and not have to worry about maxing out the pump. Probably get both for less than 100 with a spare pump... ECU: I recommend considering a microsquirt/megasquirt, or one of the many other standalone systems. The Audi system is EXTREMELY complicated and has one of the hardest learning curves I've seen. Its really powerful and can be paired down but its way overcomplicated for you who is not using the Audi dash. You can also do flex fuel with the aftermarket systems and have internal boost control or water injection control. Axles: You can change the flanges on the transmission for the 100mm axles, or go with custom axles. The 100mm flanges are difficult to find but are on the standard boxster transmission. Front motor mount: Not needed. Mike and I run without. Rear trans mount: Use 911 sport mounts ($30?) and then fab up something. Mike built a cradle. I built separate mounts from tube steel. Exhaust: Lots of different manifolds available. I would go with a bottom mount manifold/log manifold. Top mounts make it tight to the 914 body, while bottom mounts can be much more forgiving. I Have the APR Iconell manifold. It'll never crack or break and is very good flowing but finding one is almost impossible and expensive. I had one left over from my APR stage 3 kit from my Audi. They are a PITA to mount though... Intercooler. A small air to water could be plenty and compact. You wont get the airflow for an air to air system. Turbo: GT28(RS?) is a great turbo. feels like a v8 with its instant power. You can also look at the many hybrid turbos on the market that will give similar power but on a bolt on system to the factory manifold. Look at Frankenturbo Chip: See ECU Injectors: 440's will support about 275 wheel (I make 260awhp on a GT28RS almost maxing out the system on a stock fuel pump), 660's will leave you with headroom for E85 or some mixing. Hydro clutch pedal: There are some members that have made some kits that are not bolt in but surely are a decent starting point. I cant remember the name. A search should find it. I did 260awhp on 19psi or around 330chp. Very very fun motor when it was in a 3300lb car. Mikes car makes about that and is a blast. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:05 AM |
