Downerman |
Member ![]() ![]() Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None ![]() |
Can't make an injector squirt. Was trying the cold start valve and then read where it had to be cold...like real cold for California as it in the high 80's today and I see it's also connected to a temp sensor so it's no wonder why that was not squirting on start. I was thinking of it as a prime of sorts for a engine cold start.
Anyway I digress. The overall problem is I crank and nothing. I smell some fuel but no leaks. Ignition was testing using Pelican parts protocol and it all checked out. As soon as the wife get's back I will actually pull a plug and see for myself at the plug but it would seem all is well there so I'm looking at fuel. MPS ohm'd out and has tangerines new diaphragm in it. I pulled an injector and checked voltage at the 2 wire plug with the starter blazing away and I got minimal voltage. I believe it was under a volt. What should that be? Can I check the injector by applying a 12V supply to the two pins? It ohm'd out at 2.5 For the record, I primed the fuel system my applying 12V to the pump for a minute. I'm at 31 not 28 based on others who have a slightly larger displacement and that's spot on. My old problem of no 1.5 burst of the fuel pump has been fixed with another ECU. So, when that 1.5 second burst happens does it also open the injectors and prime the cylinders? So close and yet so far. Dave |
Downerman |
Again, great info and I appreciate it. So yesterday started good. Pulled all the injectors and cold start that would not do squat with a quick 9 Volt. Used Windex with ammonia and my sonic bath cleaner and after about 30 minutes they were all working except one that took another 30 minutes.
Thought that was going to be it.... Nope. So found TDC and checked pug wires, timing and while I was at it... .checked the valves. Weird stuff Maynard..... ALL the exhaust valves were way off. Had to back them off considerably. Intakes were pretty close. That's 006 on intake and 008 on exhaust. Has me kind of freaked out thinking I wore the cam lobes just working through the original ECU problem and now this but the intakes were good. So today I'm going to pull the injectors and place them in small plastic containers and see how they perform in the car and not on the bench. Second thing is I'm going to do a compression check on all four cylinders. Dave |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:38 PM |
