Downerman |
Member ![]() ![]() Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None ![]() |
Can't make an injector squirt. Was trying the cold start valve and then read where it had to be cold...like real cold for California as it in the high 80's today and I see it's also connected to a temp sensor so it's no wonder why that was not squirting on start. I was thinking of it as a prime of sorts for a engine cold start.
Anyway I digress. The overall problem is I crank and nothing. I smell some fuel but no leaks. Ignition was testing using Pelican parts protocol and it all checked out. As soon as the wife get's back I will actually pull a plug and see for myself at the plug but it would seem all is well there so I'm looking at fuel. MPS ohm'd out and has tangerines new diaphragm in it. I pulled an injector and checked voltage at the 2 wire plug with the starter blazing away and I got minimal voltage. I believe it was under a volt. What should that be? Can I check the injector by applying a 12V supply to the two pins? It ohm'd out at 2.5 For the record, I primed the fuel system my applying 12V to the pump for a minute. I'm at 31 not 28 based on others who have a slightly larger displacement and that's spot on. My old problem of no 1.5 burst of the fuel pump has been fixed with another ECU. So, when that 1.5 second burst happens does it also open the injectors and prime the cylinders? So close and yet so far. Dave |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,965 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
If engine was rebuilt and never run then the scenario where they were mis-adjusted at assembly is reasonable.
Downerman |
If engine was rebuilt and never run then the scenario where they were mis-adjusted at assembly is reasonable. LOL that would be me!! and I take full responsibility. I think my senior moments are getting serious. So I have: Cylinder 1, 135Lbs Holds pressure Cylinder 2, 125Lbs Holds Pressure Cylinder 3, 140 Lbs Holds Pressure Cylinder 4, 140 Lbs Holds Pressure. The rings haven't even been seated. I also have fuel at each injector. I have spark when cranked, plug/wire to tin. Cylinder 2.....will check them all after lunch when wife get's back. |
Downerman |
If engine was rebuilt and never run then the scenario where they were mis-adjusted at assembly is reasonable. LOL that would be me!! and I take full responsibility. I think my senior moments are getting serious. So I have: Cylinder 1, 135Lbs Holds pressure Cylinder 2, 125Lbs Holds Pressure Cylinder 3, 140 Lbs Holds Pressure Cylinder 4, 140 Lbs Holds Pressure. The rings haven't even been seated. Also wondering about my fuel. I put 91 Octane in the tank before Christmas thinking I would be getting the engine in and firing it up. Shit happens and it's been 5 months. But I DO have fuel at each injector. I have spark when cranked, plug/wire to tin. Cylinder 2.....will check them all after lunch when wife get's back. |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:06 PM |
