Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,994 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
I purchased my first 914 back in 1987 (1973 1.7L) and had that car for nearly a decade and I personally put over 100,000 miles on it before it ultimately fell victim to a negligent driver that drove into the back end of it at about 40 mph while the vehicle was stopped at a red light. That rear end crash totaled the vehicle but what is amazing is how well it crumpled (early crush zones!) due to the kink in the frame where the halfshafts are. Everyone walked away unharmed.
I replaced it with a 1991 Miata. Great car in its own right but I've always missed my 914. Purchased this "replacement" in May 2018 as a known poster child for a complete right side longitudinal rustoration. This vehicle had been put into storage inside a pole barn around 2004 as far as I can tell. Vehicle initially purchased in non-running condition: Engine couldn't be started. Transmission shift linkage was disconnected Half shafts and CV's were in pieces, and the wheel stubs were not installed therefore the vehicle couldn't even be rolled without risking having the rear wheel separate from within the bearing. Fiberglass laid into the floorpan . . . that can't be a good sign. Vehicle looks great . . . until I got under it. I spent the better part of the summer putting the items above back together and trying to confirm that it would: 1) Run under its own power 2) Drive though the neighborhood and shift though all gears. ![]() Looks pretty nice eh? Here is what is lurking underneath once the rockers came off. ![]() and when I started cutting back the rust. Oh my . . . . ![]() |
Superhawk996 |
On a more positive note. Most of the other engine components are in pretty good shape upon 1st look.
Lots of oil leaking on the case from push rod tubes, some weepage at the base of the cylinders. Crank seals are hard as rocks and leaking profusely from getting it running and the brief neighborhood drive. Oil cooler seals were hard too and leaking. Oil pressure sensor hole is indeed stripped and leaking and will need to be re-tapped. Overall I'm relieved to find the cylinder heads are 2.0L parts and I think the valves may be original. IIRC the exhaust valves with the little dimple in the center are the original 2.0L sodium filled valves. I'm not sure - have to do so research on that. Regardless, all valves will get replaced at rebuild. ![]() I also was happy to find the exhaust stud that I knew was missing appears to actually be a pulled timesert. The hole appears to have been drilled properly by a machine shop since it's located properly and not offset to the original stud bore. ![]() A couple of the cylinders are scored and one appear to be pretty corroded on the bottom of the bore. Probably from the long period of storage and condensation inside the cylinder forming. New pistons and cylinders planned so not a big deal. Was also happy to find the cylinders are 94mm and not some big bore conversion that machined the case or the heads. (IMG:style_emoticons/default/piratenanner.gif) ![]() I haven't had a chance to split the case yet but after pulling the oil pump, I'm pretty sure the cam was changed based on the appearance of the cam gear. I can also see that someone covered the Cam plug and the oil galleys with epoxy or something like that. Hopefully this was a preventative measure rather than some crappy fix that I've become so accustomed to finding. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:18 AM |
