'72 914 Power train swap, Removing V8, installing a .... |
jb6000 |
Apr 24 2019, 01:45 PM
Member Group: Members Posts: 52 Joined: 15-September 18 From: Ca Member No.: 22,486 Region Association: None |
Right now this car is a running 1972 914 with a 901 trans converted side shift, and a 350 SBC V8.
Salvage title car, registered etc. Calif. BMW 320 calipers up front. Renegade conversion. So there are many engines that work good in a 914. The stock 914 4 cyl is about 180 pounds. (I am not sure if that is bare long block or dressed motor complete.) The iron V8 with iron heads is about 525 pounds complete. I have a motor that is a 4 cyl. that is 225 pounds long block and about 330 pounds dressed with a turbo. It can put out 300-500 hp with equally high torque. I have a 6 spd transaxle that adds a bit of weight but is far better. So why is this 1.8 liter engine so much stronger than the original Porsche 914 1.8 liter engine? The picture on the top is the naturally aspirated 914 head, the picture below that is the new engine's with a turbo force fed head. Yamaha was in on the creation of this head. "An engine's power is limited by how much air can flow in and out of it." Roughly quoted from some smart guy. This engine has more valves than the Chevy V8. Attached image(s) |
ajracer |
May 4 2019, 07:46 PM
Member Group: Members Posts: 204 Joined: 18-April 04 From: Toronto, Canada Member No.: 1,945 |
Hi JP6000
Appreciate the follow-up comments and questions; unfortunately I am traveling and don’t have access to the files back home with access to more specific details as the build records so need to go back to reference things. Regarding your layout diagram above, the details are correct except the following items: D – mine uses 944 turbo C/V’s and reason being they are stronger and excellent axle angles. E – Axle measurements will be different as previously mentioned, as well depends up location of your transaxle and ride height of the car. I’ll update later next week on axle length and adapter thickness. F - it is my understanding the C/V’s are measured by their Outside diameters Audi is 108 mm Porsche C/V’s 914, 911, 944 many at 100 mm, 930 & newer Porsche are 108 mm. G - mine was converted to 5 lug 911 flanges / hubs. Hope this will assist you in the process of your project. Allan |
Lo-Fi Version | Time is now: 26th June 2024 - 04:15 AM |
