914 Suspension motion ratios, Comparing notes |
groot |
Nov 27 2004, 09:53 AM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
I measured my front and rear motion ratios yesterday and wanted to compare notes with any that have done the same.
For the rear suspension I took ~20 data points and did a best fit analysis to come up with 1.00 to 1.00 damper travel to wheel travel with strong statistical correlation. My front geometry is a bit different than a standard 914, so the motion ratio should be different, too. I measure ~10 points and found 0.83 damper travel to wheel travel, again with strong statistical correlation. I'm about to order my rear shocks and this is one of the bits of data they need to build the shocks. |
ottox914 |
Nov 29 2004, 08:48 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
So how low is TOO low on the front of a stock 914? I have heard a rule of thumb for this is not to let the front lower A arms go below parallel to the ground. Comments for us stock guys?
Thanks- |
Lo-Fi Version | Time is now: 25th June 2024 - 10:36 PM |
