> Wiring for an Engine Run Stand with DJet
doug_b_928
post May 6 2019, 07:32 PM
I'm building an engine stand that will serve multiple purposes (transport, storage, installation/removal, and testing/break-in). The one part I have very little clue about how to do is the wiring. I've searched the forum and have seen others express an interest in having wiring info for a test stand, but it doesn't seem to be documented anywhere. So, hopefully this thread will help not only me, but also anyone else in the future who is looking to do the same.
I'm going to have the djet 'computer', manifold pressure sensor (MPS), decel valve, fuel pump, and regulator plate/relay board mounted to the stand. The ground that normally connects the battery/engine to the chassis will be grounded to the stand. The wiring for the MPS will be connected to it and the wiring for the fuel injectors, alternator, and 12 pin connector will all be connected to the regulator plate. In other words, it is as if the engine were in the car with the exception of the wiring connections at the 14 pin connector on the regulator plate.
On the stand's 'dash board' I think (please correct me if I'm wrong) I need an ignition toggle switch, a momentary starter switch, an oil pressure 'idiot' light (I'm getting a cheap LED light on sale tomorrow), a tachometer (I have a cheap, generic one from FLAPS), and lever with a cable for controlling the throttle.
So the question is, what is the correct way to wire these items? I have the figures from Jeff Bowlsby's webpage and the wiring diagrams. What I'm missing is the theory of what I need to do wiring-wise to make the engine run and get the feedback to the tachometer and idiot light. I'm hoping others who appear to have done this can chime in with their thoughts (paging @StratPlayer @VaccaRabite @michelko @mb911 @barefoot ) and wiring gurus (like @JeffBowlsby ). I assume I run wires from the battery to the two power pins on the 14 pin connector, so that the regulator plate has power. After that, although I think it should be pretty simple, I'm not 100% on how to wire the ignition, starter, tach and idiot light to the 14 pin connector. Please advise.
Spoke
post May 6 2019, 09:47 PM
Jerry
Here's a schematic of the relay board to help with the connections.
In addition to the pins below, you'll need a heavy cable bolted from the battery to the starter as well as a heavy cable bolted to the case of the engine. When I tested an engine I would use a hollow transmission case I got from Dr. Evil to mount the starter.
I assume you have a master ON/OFF switch to these electrics from the battery. This would be your ignition switch. Should be a heavy switch much like an AC light switch (15A). Assume the name for this switched 12V signal is VCC. You may want to fuse VCC to the electrics just in case of a short. A 25A or 30A fuse would do.
The connections of the 14-pin relay board connector to the cabin:
Pin 1: Starter: Connect a push-button switch between this pin and VCC. Should be able to handle 10A
Pin 2: Gen Light: Connect an incandescent light from this pin to VCC.
Pin 5: Oil Pressure: Connect a lamp from this pin to VCC.
Pin 7: Tachometer: Connect the tachometer input to this pin.
Pin 8: Ignition: Connect to VCC.
Pin 10: Ground: Connect to negative terminal of the battery.
Pin 12, 14: Battery: In the car these pins are powered 100% of the time. Here it could be connected to VCC.
Pin 13: Fuel pump: Connect the positive terminal of the fuel pump to this pin. The negative terminal of the fuel pump should be connected to ground.
doug_b_928
post May 7 2019, 05:39 AM
@Spoke --This is terrific, thank you so much!!! I'll study what you've said and report back with questions for clarification.
@Literati914 --As suspected, this thread is badly needed. Glad it will help more than just myself.
doug_b_928   Wiring for an Engine Run Stand with DJet   May 6 2019, 07:32 PM
Spoke   Here's a schematic of the relay board to help ...   May 6 2019, 09:47 PM
doug_b_928   @Spoke --This is terrific, thank you so much...   May 7 2019, 05:39 AM
Literati914   this is soo timely for me.. been thinking on this ...   May 6 2019, 09:52 PM
doug_b_928   Thanks again for the SUPER CLEAR and straightforwa...   May 7 2019, 06:43 AM
Spoke   Thanks again for the SUPER CLEAR and straightforw...   May 7 2019, 07:37 AM
doug_b_928   [quote name='Spoke' date='May 7 2019, ...   May 7 2019, 07:58 AM
Spoke   The positive one should have an extra small wire...   May 7 2019, 09:42 AM
VaccaRabite   Hey Doug The Gen light needs to be incandescent a...   May 7 2019, 07:44 AM
doug_b_928   Thanks for chiming in Zach. I was thinking a fuse...   May 7 2019, 08:13 AM
Mark Henry   Watching this, I have a test stand, but what I nee...   May 7 2019, 07:54 AM
doug_b_928   Oh, okay, so the big positive cable is only to the...   May 7 2019, 09:51 AM
doug_b_928   I'm making good progress on the stand, but hav...   May 11 2019, 08:59 AM
Spoke   Maybe this schematic can clear up some questions. ...   May 11 2019, 09:09 PM
Spoke   This is the type of positive battery cable to use....   May 11 2019, 09:17 PM
doug_b_928   That's very helpful, and professional, thanks ...   May 12 2019, 07:05 AM
doug_b_928   I purchased this switch for the VCC switch and sta...   May 15 2019, 05:01 PM
doug_b_928   In thinking about it, I’m guessing that I had th...   May 15 2019, 08:54 PM
doug_b_928   Overthinking, again... I’ve realized that I had...   May 16 2019, 03:15 PM
doug_b_928   Many thanks to Spoke for all of his helpful inform...   May 16 2019, 05:02 PM
doug_b_928   I finally got my engine run stand completed. It t...   May 23 2019, 08:51 PM
bbrock   Wow Doug! That is the mother of all run stand...   May 23 2019, 08:56 PM
Superhawk996   :D Nice stand. Great job! I'll likely ...   May 24 2019, 03:44 AM
doug_b_928   Thanks guys. I didn’t know that about break-in....   May 24 2019, 06:17 AM
Superhawk996   Thanks guys. I didn’t know that about break-in...   May 24 2019, 06:50 AM
VaccaRabite   The break in that I used is the Raby method from m...   May 24 2019, 07:08 AM
doug_b_928   Interesting info on break-in, guys. Jake's me...   May 25 2019, 07:30 AM
Superhawk996   I was wondering what you were going to do with tha...   May 25 2019, 07:55 AM
doug_b_928   Well....I admit that some leaked on the concrete b...   May 25 2019, 10:52 AM
cary   Thanks doug b 928, Jack and I are about ready to s...   Nov 28 2019, 10:31 AM
doug_b_928   Post up some pics/link to vid when you get it done...   Nov 28 2019, 10:40 AM
cary   D Jet was just plug and play coming out of the rel...   Nov 28 2019, 10:43 AM
doug_b_928   I'm not sure exactly what you're asking. ...   Nov 28 2019, 10:46 AM
cary   That was the question. As it is. Didn't see a...   Nov 28 2019, 11:13 AM
cary   Here's a couple shots of our progress. Engine ...   Dec 21 2019, 01:19 PM
doug_b_928   Looks really nice Cary!   Dec 22 2019, 07:54 AM
BeatNavy   That is a super sweet setup, Cary. Wouldn't e...   Dec 22 2019, 08:10 AM
Spoke   Nice looking stands. One thing I noticed about th...   Dec 22 2019, 09:28 AM
cary   Spoke ??? I ran separate fused wires to 12 & ...   Dec 30 2019, 11:12 AM
Spoke   Spoke ??? I ran separate fused wires to 12 ...   Jan 2 2020, 10:06 AM
cary   After sitting 8 years assembled the DP engine fina...   Jan 2 2020, 09:46 AM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 02:39 PM
