groot |
Dis member ![]() ![]() ![]() Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 ![]() |
I measured my front and rear motion ratios yesterday and wanted to compare notes with any that have done the same.
For the rear suspension I took ~20 data points and did a best fit analysis to come up with 1.00 to 1.00 damper travel to wheel travel with strong statistical correlation. My front geometry is a bit different than a standard 914, so the motion ratio should be different, too. I measure ~10 points and found 0.83 damper travel to wheel travel, again with strong statistical correlation. I'm about to order my rear shocks and this is one of the bits of data they need to build the shocks. |
groot |
Angled down towards the wheel (better than parallel) to the ground is a decent rule of thumb, but .... see my signature.....
You can always just drive it and have fun (IMG:style_emoticons/default/wink.gif) and not stress about it. If the roll center is too low, you just need more roll stiffness to counter it. I think that's why there are so many big ARBs for the 914. Since I know I'm not Montoya I need to build a car that is easier to drive and I like the engineering exercise behind it all. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:25 PM |
