defianty |
Senior Member ![]() ![]() ![]() Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None ![]() ![]() |
I want to glue on my sail panel vinyl but I've been warned to give the paint plenty of time to gas off. It's been about six weeks now. Is that long enough?
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I would think so, but yes ask. Also make sure the glue has fully flashed or you risk bubbles.
914_7T3 |
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,854 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California ![]() ![]() |
I would think so, but yes ask. Also make sure the glue has fully flashed or you risk bubbles. @Mikey914 Can you explain what you mean by fully flashed? |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,326 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I would think so, but yes ask. Also make sure the glue has fully flashed or you risk bubbles. @Mikey914 Can you explain what you mean by fully flashed? The biggest mistake that people make when using contact cement is not letting it dry first. It's better to let it dry 2-3x as long as directions than too short. Also, the second coat will reactivate the first coat so again, let it dry. You usually need at least two coats on fabric. |
914_7T3 |
I would think so, but yes ask. Also make sure the glue has fully flashed or you risk bubbles. @Mikey914 Can you explain what you mean by fully flashed? The biggest mistake that people make when using contact cement is not letting it dry first. It's better to let it dry 2-3x as long as directions than too short. Also, the second coat will reactivate the first coat so again, let it dry. You usually need at least two coats on fabric. What is the recommended brand of contact cement for sail panel vinyl? |
Lo-Fi Version | Time is now: 20th June 2024 - 05:59 AM |
