> Fuel pump for carbs on a '75, help
mtndawg
post May 15 2019, 10:16 PM
I have been following the directions in other posts to wire my car for carbs with a low pressure pump under the tank. In front I have a black/red wire and brown for ground which is expected. My number 13 pin on the 14 pin connector is green rather than black with red. I can't find a diagram of a '75 relay board and it's not in my manual. The previous owner had blue a jumper wire connected as shown in the photo. Is this arrangement right for this year when running carbs?
mtndawg
post May 17 2019, 08:09 AM
I have power on both sides of the fuse
Tested the relays and they all switch when power is applied
Confirmed that the ‘75 has a green wire from pin 13 and changes to a black and red wire under the dash to connect to the fuel pump, this must be specific to ‘75 and ‘76 cars?
Maybe I have a problem with 85 or 86 on the power supply relay which is not sending signal to the fuel pump relay switch?
- Lo-Fi Version Time is now: 2nd February 2025 - 03:49 AM
