groot |
Dis member ![]() ![]() ![]() Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 ![]() |
I measured my front and rear motion ratios yesterday and wanted to compare notes with any that have done the same.
For the rear suspension I took ~20 data points and did a best fit analysis to come up with 1.00 to 1.00 damper travel to wheel travel with strong statistical correlation. My front geometry is a bit different than a standard 914, so the motion ratio should be different, too. I measure ~10 points and found 0.83 damper travel to wheel travel, again with strong statistical correlation. I'm about to order my rear shocks and this is one of the bits of data they need to build the shocks. |
groot |
That's how I see it.
I didn't increase the angle between the strut and knuckle, but I do have custom (read home modified) knuckle/strut assemblies. Eric would have to enlighten us on how he's going to do that. I worried less about the scrub radius and more about roll center, right or wrong. I did raise the steering rack to reduce bump steer. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:35 PM |
