> Fuel pump for carbs on a '75, help
mtndawg
post May 15 2019, 10:16 PM
I have been following the directions in other posts to wire my car for carbs with a low pressure pump under the tank. In front I have a black/red wire and brown for ground which is expected. My number 13 pin on the 14 pin connector is green rather than black with red. I can't find a diagram of a '75 relay board and it's not in my manual. The previous owner had blue a jumper wire connected as shown in the photo. Is this arrangement right for this year when running carbs?
mtndawg
post May 18 2019, 02:50 PM
Had the relay board out testing everything I could think should have continuity and everything checked out along with getting 12 volts in all the right locations. I put it all back together to test for voltage at the pump. When I turned the key it went on! I don’t know what the problem was. Moving forward for now.
Spoke
post May 18 2019, 02:57 PM
Jerry
QUOTE(mtndawg @ May 18 2019, 04:50 PM) *
Good to hear although it is also good to find the issue and fix it. Many times electrical issues stem from poor contact at connectors. Removing and reinserting connectors sometimes makes better contact and things run again. Let's just hope the issue doesn't come back. (IMG:style_emoticons/default/beerchug.gif)
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 2nd February 2025 - 03:58 AM
