jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
Well, I finally got around to taking some measurements. I did not take the mirrors off, but rather took measurements from 3 points on each door to the base of the rubber gasket. On this first picture...the key to the alignment is the yellow line...that line when looking at the car from the front should be vertical on both sides!
Also, for strength, you must use the 911 backing plate. I riveted mine on after having the holes cut in. Drivers side: Attached image(s) ![]() |
jim912928 |
I have installed flag mirrors....I have wondered if anybody did a glass mount boxster mirrors though...intriguing thought.
Lo-Fi Version | Time is now: 26th June 2024 - 05:10 AM |
