Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,005 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Playing with the idea of what it will take to rebuild a type 4 pump.
The pump that came out of my 2.0L engine is trashed from pumping rust. Both the gears and the housings are seriously scored. ![]() I figured I'd roll the dice and see what might be on Ebay. Took a gamble and bought a used pump hoping I might get some core parts that are useful. ![]() I did end up with a good housing outer. However, the gears are pitted and it the inner housing plate either has a serious casting flaw, or some sort of galvanic corrosion that pitted it. I always struggle with this kind of thing. It really would have minimal effect on the pump and it probably worked OK for a lot of years. However, I'd just like to know that it is perfect going before going into a engine. ![]() ![]() It looks like new inner plates are available but at a cost of $150+. I decided that since I have a donor "scrap" pump, I have nothing to lose by experimenting with machining it. |
North Coast Jim |
Member ![]() ![]() Group: Members Posts: 339 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region ![]() ![]() |
I bought a new Melling pump. Made in Michigan from what I've been able to determine, Its a high flow pump and is a bit thicker than stock. Runs a thinnnnnnn gasket as a result. Make sure your case is flat in the area where the gasket needs to seal. Had to take the engine out to redo the seal. Great oil pressure. $90 bucks IIRC
Superhawk996 |
I bought a new Melling pump. Made in Michigan from what I've been able to determine, Its a high flow pump and is a bit thicker than stock. Runs a thinnnnnnn gasket as a result. Make sure your case is flat in the area where the gasket needs to seal. Had to take the engine out to redo the seal. Great oil pressure. $90 bucks IIRC I've considered the Melling. Not convinced the cast iron pump in an aluminum case is the best way to go. However, of the options I've found so far a T4 rebuild actually seems most appealing as a direct fit replacement. |
Lo-Fi Version | Time is now: 26th April 2025 - 07:51 PM |
