> Type 4 oil pump rebuild, Comparison of OEM vs. Samba CNC pump
Superhawk996
post May 26 2019, 05:51 PM
Playing with the idea of what it will take to rebuild a type 4 pump.
The pump that came out of my 2.0L engine is trashed from pumping rust. Both the gears and the housings are seriously scored.
I figured I'd roll the dice and see what might be on Ebay. Took a gamble and bought a used pump hoping I might get some core parts that are useful.
I did end up with a good housing outer. However, the gears are pitted and it the inner housing plate either has a serious casting flaw, or some sort of galvanic corrosion that pitted it. I always struggle with this kind of thing. It really would have minimal effect on the pump and it probably worked OK for a lot of years. However, I'd just like to know that it is perfect going before going into a engine.
It looks like new inner plates are available but at a cost of $150+.
I decided that since I have a donor "scrap" pump, I have nothing to lose by experimenting with machining it.
Valy
post May 26 2019, 09:40 PM
Number 1 reason for failing oil pumps is the idle axle getting loose and backing out into the camshaft.
Make sure that axle is well fixated.
All the other wear I see there is not nice, will cause some efficiency loss but won't really fail the pump unless really bad or the gears start having axial play.
Superhawk996   Type 4 oil pump rebuild   May 26 2019, 05:51 PM
Mark Henry   Personally I'd use a new modified T1 pump and ...   May 26 2019, 05:59 PM
Superhawk996   Personally I'd use a new modified T1 pump and...   May 26 2019, 06:07 PM
Superhawk996   I decided to start with my original pump inner hou...   May 26 2019, 06:02 PM
North Coast Jim   I bought a new Melling pump. Made in Michigan from...   May 26 2019, 06:10 PM
Superhawk996   I bought a new Melling pump. Made in Michigan fro...   May 26 2019, 06:23 PM
Superhawk996   @North_Coast_Jim How many miles on the melling? ...   May 27 2019, 04:50 AM
North Coast Jim   @North_Coast_Jim How many miles on the melling? ...   May 27 2019, 06:01 AM
Superhawk996   So here is the cover with just a skim cut and the ...   May 26 2019, 06:19 PM
914sgofast2   There is a thread over on the Samba with a step by...   May 28 2019, 08:17 AM
Superhawk996   Ultimately I may machine up some sort of test fixt...   May 26 2019, 06:26 PM
Valy   Number 1 reason for failing oil pumps is the idle ...   May 26 2019, 09:40 PM
Superhawk996   Number 1 reason for failing oil pumps is the idle...   May 27 2019, 04:28 AM
Valy   @Superhawk996 It works well, no issues so far but...   May 27 2019, 02:12 PM
Mark Henry   T1 mod is easy if you have a lathe, you just have ...   May 28 2019, 09:33 AM
Superhawk996   Given that I'm a mechanical masochist I haven...   Aug 4 2019, 10:59 AM
914sgofast2   Try visiting The Samba.com website and go to the 4...   Aug 4 2019, 12:22 PM
Superhawk996   :agree: Been there before. https://www.thesamb...   Aug 4 2019, 01:00 PM
Archie   I've had one listed on FS/WTB for a couple of ...   Aug 4 2019, 05:17 PM
Superhawk996   Time to light up an old thread. I continue to bui...   Sep 19 2021, 10:02 AM
Superhawk996   Used T4 mystery pump. Heres a caution to anyone ...   Sep 19 2021, 10:59 AM
Superhawk996   T4 Mystery Pumps -- The plot thickens Recently bo...   Dec 6 2021, 10:51 AM
Nogoodwithusernames   Another thing to keep an eye out for is the small ...   Dec 6 2021, 01:13 PM
- Lo-Fi Version Time is now: 14th December 2025 - 05:24 AM
