Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,005 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Playing with the idea of what it will take to rebuild a type 4 pump.
The pump that came out of my 2.0L engine is trashed from pumping rust. Both the gears and the housings are seriously scored. ![]() I figured I'd roll the dice and see what might be on Ebay. Took a gamble and bought a used pump hoping I might get some core parts that are useful. ![]() I did end up with a good housing outer. However, the gears are pitted and it the inner housing plate either has a serious casting flaw, or some sort of galvanic corrosion that pitted it. I always struggle with this kind of thing. It really would have minimal effect on the pump and it probably worked OK for a lot of years. However, I'd just like to know that it is perfect going before going into a engine. ![]() ![]() It looks like new inner plates are available but at a cost of $150+. I decided that since I have a donor "scrap" pump, I have nothing to lose by experimenting with machining it. |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
Number 1 reason for failing oil pumps is the idle axle getting loose and backing out into the camshaft.
Make sure that axle is well fixated. All the other wear I see there is not nice, will cause some efficiency loss but won't really fail the pump unless really bad or the gears start having axial play. |
Superhawk996 |
Number 1 reason for failing oil pumps is the idle axle getting loose and backing out into the camshaft. Make sure that axle is well fixated. All the other wear I see there is not nice, will cause some efficiency loss but won't really fail the pump unless really bad or the gears start having axial play. @valy Nice engine build thread! Hadn't seen it before. How many miles do you have on your type 1 pump now? Any issues with leakage or higher oil temps? Type 1 is tempting. |
Lo-Fi Version | Time is now: 26th April 2025 - 08:02 PM |
