Starter Issue, Starter does not respond to ignition switch |
downrange |
Jun 3 2019, 09:55 AM
Newbie Group: Members Posts: 22 Joined: 1-January 18 From: Pennsylvania Member No.: 21,747 Region Association: MidAtlantic Region |
Restoring 1974 914 1.8 liter L Jetronic. No starter response to ignition switch. Replaced original starter - no luck. Installed Bosch Starter Relay Hot Start Kit - No luck. Cleaned ground connections to transmission ground strap - no luck. Any suggestions?
If not obvious, I am like a monkey with a iPhone when it comes to auto electronics. |
dr914@autoatlanta.com |
Jun 3 2019, 10:32 AM
914 Guru Group: Members Posts: 8,114 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
see if you are getting 12v to the yellow lead with the key engaged to the start position. If not check the ignition switch and the interlock relay under the pass seat. If so then check the transmission ground strap and the positive cable connected to the battery and the starter
Restoring 1974 914 1.8 liter L Jetronic. No starter response to ignition switch. Replaced original starter - no luck. Installed Bosch Starter Relay Hot Start Kit - No luck. Cleaned ground connections to transmission ground strap - no luck. Any suggestions? If not obvious, I am like a monkey with a iPhone when it comes to auto electronics. |
Lo-Fi Version | Time is now: 6th January 2025 - 05:51 PM |
